Technical question on the relation of ignition timing to compression/piston dish
Ok so I'm hoping some of the real knowledgeable tech guys on the forum can weigh in on this (preferably people who have spent some real dyno time playing with timing on different types of motors).
My motor is a stock bottom end, 4- bolt main 350 (-18cc dished pistons) with Brodix IK200 aluminum heads (64cc chambers) and .015 shim head gasket to help raise the compression on those cast dished pistons. That gives me roughly 9.4:1 compression. I'm running a Lunati 268 cam (227/233 duration at .50", and around .500" lift)
I have my timing set at 36 degrees total (20 initial, 16 mechanical) and I run 91 octane no-ethanol gas. What I"m trying to figure out is how much timing would be optimal for power. I do plan to get it on the dyno in the near future to experiment, but I'm curious how people do it without dyno time. I've heard some of the old methods of "turn it up till it pings, that back it off two degrees", but I doubt that is accurate for finding the optimal timing for max power.
In doing some reading, I've seen some references to lower compression motors with poor combustion chambers (mine is a poor piston design with a head that has a great combustion chamber) needing more timing, closer to 40 degrees. But I've also seen guys with 10:1 compression motors (not that much more than mine) making optimal power at 32 degrees. I assume the cam events and static vs dynamic compression play a significant role.
So how do you determine close to optimal timing without dyno time? Or is dyno time the only accurate way?
I have spent alot of time tuning my Quadrajet under the assumption that my 36 degrees total was optimal, but I'm realizing that I should really get that timing dialed in perfect THEN go back and fine tune on the carb.
Everything I've seen on this forum for years says 36 total for cast iron heads and less, about 32, for aluminum heads but nobody can give you the perfect number within that range for your engine unless you dyno it .
I want to add something that might help. Dyno "tuning " is just that. Tuning of the engine. In my case, I don't go for maximum horsepower. The dyno can tune the engine for much better & smoother drive-ability. That is, all the time we drive the car around at normal speeds. I had a Road Runner that was built-up & could be a little grumpy until it was tuned on a dyno. Same horsepower, but easier to drive.
Hope this helps.
Hope this helps.
IMO, there is NO other way to "accurately" tune the motor to optimum performance without a dyno, that's what they are designed to do in the hands of a skilled tuner. How do you know you have the correct/optimum A/F ratio at WOT right now?
Actually...you tune the your VE or fuel first, then dial-in the SA or spark on any dyno.
I think I answered my own question: I just need to bite the bullet and go get it dynoed.
To be honest, it probably won't be that expensive since I won't be having them touch the carb (doubt I could find someone around here who knows how to tune the Qjet anyway, and I can make any changes I may need). So the dyno runs would really just be to verify timing. I would think 3-5 runs would be sufficient. One baseline run with my current 36 degrees. Drop it a couple degrees and see how it responds, raise it a couple degrees and see how it responds. Then a run at the end to verify the change in power. I really just need someone to operate the dyno for me while I test haha.
Hope this helps.
Hope this helps.
I should go take it to a dyno shop. I am verifying my A/F with a wideband 02 that I welded into the exhaust, excellent tuning tool!
The 36 degrees works best for the old original wedge combustion chambers. The newer style combustion chambers need less total advance because they burn faster. This is a good place to start because you will already be in the ballpark.
Idle and cruise are both around 15:1, so I could probably lean my cruise out a tiny bit more.
Thanks!
Hence the dyno time haha, but I am curious about the science behind it.
Fuel atomization and exhaust gas dilution have the biggest effect BSFC (Brake Specific Fuel Consumption) Which means how many pounds of fuel are needed to make HP. Another term you need to understand is VME ( Volume Metric Efficiency) Or how much HP are you producing per CI.
The shop had a dyno and I helped dyno tune motors that had to be ready to go when the owners showed up at the track. The boss never tuned for the highest numbers. He always went for the highest average hp and VME along with the best BSFC.
In a carbed motor fuel atomization is all about starting with the tinniest fuel droplets suspended in air and keeping the intake track at a high speed without turbulence to keep the atomized fuel from creating larger droplets. You have to start out with high air velocity over the best downleg or annular type boosters with correct air bleeds emulsifying the incoming fuel. Then your manifold has to continually decrease in size on the way to the intake valve creating a ram effect during the intake opening. You can't have smaller intake port than the head port. The cylinder head, piston design, and exhaust tuning determines how low the exhaust gas dilution is. It is just reasonable to conclude that the higher the C/R the less exhaust dilution. Intake ram effect and valve overlap can actually be sending fresh fuel out the exhaust pipe. tuned exhaust can create both positive and negative pressures in the exhaust port over a limited amount of RPM. Free flowing dual exhaust and side pipe system can decrease the exhaust pumping losses to a motor. But the ultimate is a correct primary diameter and length going into a merge type collector of the correct dia. and length to open air.
The cylinder head design with correct quench causes atomized fuel to become a plasma at the point of ignition. That is where you get the highest efficiency burn and that is at the point of the highest TQ on a dyno run.
That is why an engine can run very well with 2000 cfm using 8 intake stacks. Where a stock type dual plane is over carbed with an 850 cfm because of the poor port design. You want the best tuned carb, a tuned intake port and heads, compression within reason, and a tuned exhaust system. That is why I went to single plane intakes to match the heads. Tuned long tube headers and three inch exhaust system for street and header collector extensions for open to air drag racing.
Watch the important numbers not just A/F ratio.
mobird (08-20-2018)
Received 1,877 Likes
2017 C2 of Year Finalist
And READ the plugs. Give the motor what it wants...not some arbitrary A/F ratio or timing figure. All of that is great to start with...but every combo is different.
The pistons you describe aren't going to be as efficient as a true 'D" dished one that matches chamber. There really is very little quench with OEM dished pistons...so that's out the window. Things that impact oxygen remaining in the exhaust (big cams) can make "normal" numbers inaccurate for what it's going to take to make that particular combo run.
JIM
JIM
mobird (08-20-2018)
Just thinking out loud. There has to be other side effects to the wrong ignition point. We all know that too early ignition leads to ping. I would suspect that too late ignition would result in higher exhaust temps, and possibly more CO, HCs or NOx Temperature would be the easiest to measure.
Dr. Detroit
Received 3,892 Likes
The IK head does not have the fast burn chambers on them so 36 degrees is a good start. The only real way to know what timing to use is to read the plug strap after a hard full throttle 1/4 mile run. Too little timing will see the "burn" point higher up and over the strap.......too much will pepper the strap and the "burn" mark will be way down the side of it. This is the exact procedure we used on our race engine on a stand alone dyno years ago and it works......we would read the plug by pulling a "sweep" run at about 3/4 load (water) to see where the timing was at to get a ballpark before throwing everything at it.
The engine will basically want what it wants.......no set rules about where it should be given a combo. As Jim said above, your quench is horrible so it would not surprise me that you would actually end up with less total timing due to this.........
I built a 350 for my Dad 20 years ago off of a Goodwrench crate motor.......threw everything out except the short block and installed Edelbrock heads (Performer RPM).......this had the same crummy pistons in it that you have......but it ran very well. With a 64cc chamber I ended up at 35 degrees for max power. This was with a 292H Magnum Comp Cam.
Have Fun
Jebby
Have Fun
Jebby
mobird (08-20-2018)
iirc, Nox is reduced by high exhaust temperature.
Shop around for dyno costs My local shop in Manassas, VA charges $75 for three pulls and $15 for each additional pull. Cost is for HP and torque results only. A/F reading is add'l $15. If they do not have to do any of the timing adjustments, there is no charge for the car owner to quickly change the ignition timing between runs. With what you are looking for you should spend less than $200.
JIM
JIM
