What afr should be with 150 shot
08-17-2018, 07:12 PM
Running a 150 shot with c16 in the stand alone. Ls3 bolt cam na wot afr:12.3 spraying afr:11.2-11.3 is this to rich? 6 degree pull
08-17-2018, 08:28 PM
Its a little conservative, but you arent going to hurt anything. Depending on what your total timing is I wouldnt pull as much timing with c16 in the tank.
08-17-2018, 10:15 PM
How much per 50 shot of timing would you pull with c16?
08-17-2018, 11:59 PM
Like I said it depends on your current total timing
08-19-2018, 09:22 AM
You want to be slighty fatter than your N/A tune-up. You're a little on the rich side right now. What's your total timing?
08-19-2018, 09:28 PM
Quote:
Originally Posted by
jayyyw
Not sure. Would have to find out. Is being on the little Rich a bad thing?
08-20-2018, 08:04 AM
On spray, rich is as dangerous as being lean.
08-20-2018, 12:07 PM
jayyyw
what would be the idea afr when spraying?
08-20-2018, 03:40 PM
11.8-12.3 is a good starting point
