Hydraulic valve adjustment
I’m about to adjust the valves in my 65 327 300 hp and seeking advice.
First, the prior owner said it had a mild Crane Blueprint cam installed but has no other info
Second, I prefer to make the adjustments with the engine running.
Jriver (08-22-2018)
I drape the inner fenders with old towels and also tuck them along the top of the exhaust manifolds up against the heads. Start it up, back off each nut one at a time until you can hear it click, tighten until the click goes away and then turn another 1/4 - 1/2 turn. I know that some would turn them further, but I am more comfortable with a 1/4 to 1/2 turn. I work quickly down one side (the valve cover is still on the opposite side. Re do it. and shut it off. Remove towels as the manifold is getting pretty warm. Replace valve cover gasket and reinstall. By then the other side is cool enough to do it.
Jriver (08-22-2018)
Received 2,127 Likes
If you insist on playing with the valves, for whatever reason, find one of many YouTube videos that shows the exact correct process. Dennis
Jriver (08-22-2018)
Received 5,547 Likes
I can understand wanting to adjust the valves, but why oh why would you ever adjust hydraulic lifters with the engine running unless you enjoy an oil bath and a fire hazard. One of the many benefits of hydraulic lifters is hot or cold lash makes no difference.
Set the engine to TDC for cylinder #1 intake stroke, loosen both #1 rockers, and tighten the rocker while spinning the push rod with your thumb and forefinger until you feel zero lash (you want to just feel the push rod slack disappear), then add another 1/4 turn and tighten the lock (check the specs for your lifters as some want another 1/2 turn). Do both #1 rockers, turn the engine 90 degrees and do #8 the same way, continue to turn the engine 90 degrees following the firing order until all 16 are complete.
59BlueSilver (08-22-2018)
I've ALWAYS adjusted hydraulic lifters with the engine running....back off till they clatter and tighten down until they just stop...then go 1/4 tighter in increments pausing for 5-8 seconds at each quarter turn to let the lifter stabilize....I usually end at 1 turn from zero lash -- many go less... Hydraulics are pretty forgiving...
Jriver (08-22-2018)
Jriver (08-22-2018)
Received 1,843 Likes
If they're not making any noise, leave the hood shut and don't screw with it.
I have an old valve cover I cut 8 holes in (using a step drill), large enuf for a socket to fit the rocker arm adj nut to fit.
With gasket and valve cover on, no muss, no fuss, no oily mess, and since i zero lash---turn down to just not clattering plus 1/8 turn, i get no lifter pump up at higher (6000 plus) RPM..
Doug
Doug
Jriver (08-22-2018)
Tether Man
Received 2,014 Likes
2019 C1 of Year Finalist (appearance mods)
Jriver (08-22-2018)
Jriver (08-22-2018)
Received 1,534 Likes
I also use a cut-out valve cover with the engine running. Frankie is giving you the best info. GM says 1 turn from 0 lash (rockers clattering). I generally don't go past 1/2 turn. When racing, I left them at 1/4 turn as the old school dictated more clearance = higher RPM, but don't know if it works. Never dominated a NHRA class.
Get an old valve cover and drill or modify it to control the oil. Then have at it one side at a time. Keep in mind the Chevy SB is the worst when it comes to cam wear and you may need the modified valve cover again as the cam goes south.
You bought the toy to play with, The more you learn about her the more you will enjoy her, the car that is.
Jriver (08-22-2018)
I will assume you either have a miss or a loud lifter and are trying to fix it.
I have used a piece of cardboard several times over the years to adjust hydraulic lifters if needed.
If memory serves me I cut it 6" high and about 24" long which gave me enough to fold it to fit just inside the valve cover opening and the oil would splash on the cardboard and run back into the head.
It is a one time use thing, use it an toss it.
It works to help minimize the oil splash mess. Now I have extra old valve covers to use which do a better job.
If you want to run the lifters at the top of the travel they make performance lifters which have a much sturdier retention spring instead of the spring clip used on OEM lifters.
If the lifter piston is tapping on the retainer spring it can pop the spring out. I have found these springs in the oil pan before.
Jriver (08-22-2018)
I'm with Factoid on this one. Can't imagine why anyone would want adjust them running.
Greg (08-23-2018)
With cut off valve covers (Westlotron-style) or oil diffusers (see link below); running adjustment is a non-issue and you get to adjust on an engine with hot oil pumping up the lifters and its easier to compensate for differences in valving or spring strength or other subtle variations in how they operate... I use the oil diffusers personally...(of course you'll have to reach into your pocket for six dollars):
https://www.summitracing.com/parts/oes-25050/overview/
do you think Chevrolet adjusted them running? Many years ago we shipped engines all over the country and several internationally. They were all adjusted on an engine stand. If we ever had a complaint about valve adjustment I can't remember it. I remember adjusting the valves on the owner of the engine shops 69 big block. I had just finished it up and I fired it up to make sure before I reinstalled the value covers. This was in the car. A guy that was a cam grinder in the sister company was watching as I cranked it up. One rocker skirted oil over the fender and it went straight down his face and shirt, couldn't have been a better shot. He starts fussing that I did that on purpose. I asked how in the hell was I supposed to know one rocker was going to do that as I'm laughing my *** off.
I don’t “think” anything. I’m telling you the best way to do it and not make a mess On a fresh build you do it statically as described above to get the car initially running.
I adjust solids running sometimes too. You’re making it a bigger issue than it is with the right setup. But do as you like it makes no matter to me.
Again the argument is that if you adjust them 1 turn, the oil pressure will pump the lifter and give it a bit more lift!
You decide, We drive these beauties with respect 12!@#$%.
Dom
If you insist on adjusting them, AND if you insist on adjusting them with the engine running... you NEED these clips.
Without them, you'll have oil squirting everywhere.... Don't ask me how I know this.
You'll also have oil draining/oozing down onto the exhaust manifolds... and down the side of the block... You can create a real oily mess real quick.
