ExtremeOnlineStore | C7 Front Splitter / Side Skirts / Rear Spoiler - Free Shipping
Supporting Vendor
Extreme Online Store | Corvette C7 Parts & Accessories SHOP NOW
Aero Package - Front Splitter / Ground Effect - Side Skirts / Rocker Panels - Rear Spoiler
Wing
Bumper Grill - Diffuser Fins -Splash Guards -Tow Hook License Plate - Floor Mats
Corvette C7 Stage 2.5 ZR1 Extended Front Splitter Air Dam $599.99
Corvette C7 ZR1 Conversion Rear Spoiler High Wing $1299.99
EOS Corvette C7 Z06 Style Stage 3 Aerodynamic Full Body Kit
C7 Carbon Fiber Stage 2 Front Splitter W/ Side Extension $449.99
C7 Carbon Fiber Stage 3 Front Splitter W/ Wickerbill Extension $539.99
Corvette C7 EOS Performance Carbon Fiber Side Skirts Rocker Panels | EOS Performance Package $299.99
Corvette C7 Grand Sport / Z06 Carbon Fiber Side Skirts Rocker Panels | Z06's Z07 Performance Package $429.99
Corvette C7 Stage 3 Rear Spoiler W/ Wickerbill Extension $469.99
Corvette C7 Carbon Flash Front Grille (Without Camera Brackets) $100.00
Corvette C7 Carbon Flash Front Grille (With Camera Brackets) $120.00
Corvette C7 Carbon Flash Rear Bumper Diffuser Fins $129.99
Corvette C7 Add On Wind Defector / Glow Plat From $279.00
Supporting Vendor
Customer Review & Photos:
Packaged incredibly well. Paint is good but not perfect. I think it may have been wrapped before it cured completely. I'll run a buffer over it and ceramic coat it before install, but I'm picky. All sorts of hardware including rivets are included. Nice setup. I think this thing is gonna look bad ***.
Finally getting around to start the install of the 2.5 splitter. Did EOS enclose any instructions or packing slip as I just opened box and did not see any.
wondering where the rivets go.
any help would be appreciated as I want this to go well. Splitter just got ceramic coated, so I plan to install tonight ir tomorrow.
Supporting Vendor
Customer Review:
Extreme Online Store front splitter/winglets
Don't use rivets, you will have to drill them out later when you scrape this one up and have to replace it. If you can get close to the factory holes, try that then elongate the holes as necessary. I wouldn't trust the tape by itself either, but it does help hold it in place if there is wiggle in the holes. Once its in place, use the screws and washers to reduce the gap created by the tape to a minimum pulling it to the user side of the bumper. As I said, I am happy with mine from @ExtremeOnlineStore once I got it installed.
I have a 2014 Stingray M7 base. I haven't been super active on the forums past few years as I've been quasi-restoring my first car ('95 Mustang). Now that I wrapped that up I've been debating whether or not to trade up to a GS, but I'm sentimentally attached to my C7 & have decided just to modify it to my liking vs trading up.
So, during Christmas/New-Years weeks I installed Z06 Style Stage 2 front Splitters, Spoilers, and Grille all in Carbon Flash Metallic.
I had to wait until we got a warm enough day to install the Stinger Stripe, which I purchased from Phoenix Graphics.
Also installed a Borla S-Type Catback.
I have no experience with GM Brand parts, but I could not fathom dropping the insane prices for genuine GM Z06 Aero bits. Extreme Online Store (EOS) had actually reasonable prices.
Now, I've been burned buying cheaper parts in the past, but EOS had good reviews for other cars on other forums, so I figured I'd take a chance. I'm glad I did; everything fit perfectly. EOS had great customer service too; they forgot to include the directions for the front splitter. Sent an email & less than 24hrs I had them
I followed Theta's video for removing the front bumper cover. I had no problem popping the cover loose by the headlights. I pulled straight up and the popped out.
I followed YT video from "Chevy Dude" for removing the rear bumper cover to install the spoiler, with a few caveats. I didn't remove the tail lights to install the nuts. I was able to use a flex-head ratcheting wrench to get them.
Another tip for installing the spoiler; line the template up as it directs you, put the studs in the spoiler, and then set the spoiler on top of the template to ensure the studs actually line up with the holes on the template. I had to make a lot of tiny adjustments to the template to get all the studs to align with the template holes. Not that it was way off, just a lot of fine tuning. Do not tape the template down & drill holes expecting it to be perfect.
Next up; I've purchased a supercharger from Andy at A&A. It'll be a few weeks until I get to that, but I'll make a thread as I install it. Maybe that S/C will help me finish burning the tread off my factory wheels & tires so I can upgrade those too
Supporting Vendor
Supporting Vendor
Supporting Vendor
Customer Review:
I have both the front splitter and side skirts in carbon flash from EOS and the fit was perfect and very easy to install. I didn't use the self tapping screws I instead used rivets and I couldn't be happier with the results.
You can spend more money and get what many perceive as better quality but I personally don't see the point. Looking at them on the car you can't tell the difference from 3 thousand dollar skirts and splitter or 600 dollar ones.
I will say this if you hit a curb or driveway approach with either of them they will be worthless garbage.
Supporting Vendor
Instagram @bloodvette
Corvette C7 Stage 3.5 Aerodynamic Full Body Kit
STAGE 3.5 #Aerokit #CorvetteParts
Supporting Vendor
Customer Review:
same. had one small issue with my order, already addressed by them, quick response as mentioned. Def will order from them again
update: installed the splitter and winglets, very happy, parts are high quality and fit well.
I will say all of the "problems" I've seen on this forum with this kit are not EOS' fault. Yes, if you already have a splitter, like I did, you will need to drill out the old rivets, which is easy, and yes the supplied bolts then won't fit as the holes are larger, I just used plastic push pins/rivets you can buy at Lowe's or O'Reilly, then the install looks original.
Supporting Vendor
Following the Carlisle show I preordered (out of stock until Sept) the carbon flash splitter shown above. It was supposed to be the discounted show price. I was charged $489. Before it shipped, I noticed Extreme Online Store had lowered the price to $439. Hey, it hadn't shipped so I thought I would see if they would cut me a deal and give me the lower price. After all, it hadn't shipped yet. So I email their customer service and ask for a partial PayPal refund. That didn't sound out of line to me. So, no response from Extreme Online, but they did issue a shipping label right away. It would be days before it actually was picked up by the carrier. So I email them again. Crickets . . . silence. So, I guess it's a lesson learned on dealing with vendors. Hope I like it when it eventually arrives.
Supporting Vendor
In fact, the price we offered will always be the best price on the market. We will not refund our customers if we adjust the price internally.
If you discover any company that offers a better price/deal than us, please let us know and we will match the pricing asap. Thank you.
Supporting Vendor
Customer Review:
Finished my EOS sideskirt and splitter install this week. Extremely happy (pun intended). I had an issue with a damaged item, not at all cause by EOS, and they QUICKLY replaced the item. The quality of their products is HIGH. Everything fit great and looks good. The Carbon Flash matches all the other Carbon Flash trim on the car.
25December2018
25December2018
Supporting Vendor
Supporting Vendor
Supporting Vendor
Supporting Vendor
Customer Services:
Supporting Vendor
Supporting Vendor
Supporting Vendor
