Where to buy tail light, bulb socket?
Old Aug 31, 2018 | 11:51 PM
castlerock_z06's Avatar
castlerock_z06
Default Where to buy tail light, bulb socket?
One of my rear lights doesn't blink when turn signal is on. Removed tail light cover and pulled socket. Switched socket with other three tail lights and fault follows socket so I assume wiring is good. Tried cleaning, pushing pins together for better contact etc with no luck. Dealer says need to buy entire harness to get socket? Anyone know of wrecking yards or any other way to buy a single socket?
thanks
Old Sep 1, 2018 | 09:11 AM
C6ToGo's Avatar
C6ToGo
Not sure if you can get just socket unless you find salvage.
Search 15780132. Ebay has some used harnesses....just make sure they are including the sockets.
Old Sep 1, 2018 | 09:55 AM
FLC6GS's Avatar
FLC6GS
Awesome car/color !! I'm biased though, I have the same as yours only a year older
To my knowledge that is correct, the individual socket is not available OEM/Aftermarket -
Item #10 (N/A)
https://www.wholesalegmpartsonline.c...rimLevel=25570
https://www.corvetterecycling.com/20...p/21994812.htm
If these threads may help though...
https://www.corvetteforum.com/forums...post1590582505
https://www.corvetteforum.com/forums...post1596149141
Old Sep 1, 2018 | 12:34 PM
BADBIRDCAGE's Avatar
BADBIRDCAGE
NAPA shows it for $9.89
part # NOE 6807008
Old Mar 12, 2021 | 06:36 PM
SullysRants's Avatar
SullysRants
Default $268 for bulb socket FU dealer
One of my sockets was heavily corroded and light was failing. You can no longer buy just the socket. Dealer wanted $268 for a whole light kit...
Luckily Dino’s Corvette Salvage had some for $25!
Old Today | 09:10 AM
KokeZ's Avatar
KokeZ
fords 13411-CA works but needs trimming to be snug inside the tail light got it from aliexpress for 1$
To Where to buy tail light, bulb socket?
