C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Holley hi rise
Old 09-02-2018, 02:51 AM
Corvettepower11
Corvettepower11's Avatar
Default Holley hi rise
How are y'all installing iat sensor or the location rather that works best
Old 09-02-2018, 11:03 PM
Corvettepower11
Bump
Old 09-03-2018, 11:17 PM
Rokket
Rokket's Avatar
I don't have a Corvette, but I drilled and tapped on the bottom of the "snout" where the TB bolts to.
Old 09-04-2018, 01:28 AM
corvettepower
corvettepower's Avatar
Ok thank you do u have a picture and the sensor you used? And on the rear did u just plug the threaded hole?
Old 09-04-2018, 02:22 AM
Rokket
Rokket's Avatar
12614717 is the part number I'm using. I am also using an IAT breakout harness to remove the IAT function from the MAF. The circled part in the picture is part of the IAT sensor but should give you an idea of it's placement.
Everything in the back of the intake is plugged up except for the biggest hole and it is being used for the brake booster and a vacuum log.
Old 09-04-2018, 02:58 AM
corvettepower
What bout ur map sensor thought it went back there
Old 09-04-2018, 03:00 AM
Rokket
Rokket's Avatar
You're correct, I forgot about it being back there.
Old 09-04-2018, 03:03 AM
corvettepower
Lol ok cool thanks for the help on that part I’m getting ready to install the hi rise and just need a lil help on configuring everything my next set of questions be concerning the evap system as far as maybe deleting it not sure if that’s what you did or not
Old 09-04-2018, 03:40 AM
Rokket
Rokket's Avatar
I deleted mine.
Old 09-04-2018, 11:44 AM
corvettepower
Ok cool thanks for all the help Blake b
Old 09-19-2018, 09:41 PM
Corvettepower11
That engine bay sick you have it setup neatly
Old 09-19-2018, 09:49 PM
Rokket
Rokket's Avatar
Thanks!
To Holley hi rise
Quick Reply: Holley hi rise
