FS: 1.6 Comp Cams Pro Magnum
SOLD! : 1.6 Comp Cams Pro Magnum
Up for sale is a complete set of 1.6 ratio Comp Cams, Steel, Pro Magnum Roller Rockers. The part number is #1605-16. I bought these from a Forum member who had them on an LT1. I then sold my car before I could get them installed. The rockers are in excellent shape and have very few miles on them. They are in the original box with all the original paperwork. The asking price is $150.00 shipped. Thanks.......
Mike,
I believe they should fit fine. Not sure about valve cover, internal clearances. They are listed as being used in all the small block chevys. You will have to replace the studs as these require a 7/16 stud. Its just a matter of changing out the stud and replacing with a 3/8 by 7/16 screw in stud. The prices I see for the studs is $30-$35 dollars a set. Ultimately whether they will work for your application should come from your research.
Thanks,
Scott
Thanks,
Scott
