Vibration
Vibration
my c6 has a vibration at 80 mph and goes away at 90 mph it's felt in the steering wheel. Does it need wheel balancing in front ?
Are they brand new tires or do they have some miles?
Retired & lovin' it!
Duh.....yes....and a rear wheel imbalance can transmit vibration thru the chassis to the steering wheel so any balancing should be done on all four wheels. Also, you don't say anything about the mileage or condition of the tires. If they are hi-mileage worn or unevenly worn due to misalignment, that will also cause wheel shake at different road speeds.
Don07 (09-12-2018)
Duh.....yes....and a real wheel imbalance can transmit vibration thru the chassis to the steering wheel so any balancing should be done on all four wheels. Also, you don't say anything about the mileage or condition of the tires. If they are hi-mileage worn or unevenly worn due to misalignment, that will also cause wheel shake at different road speeds.
tires are originals with 17,000. Miles and still in great shape.
78-82 mph seems to be the sweet spot spot for vibration on a c6 corvette. Yes get a Hunter road force balance with a good tire tech and check the tires for run out or a out of round condition.
Don07 (09-12-2018)
