Guess my hp
Guess my hp
Hey guys. I see the performance forum doesent get used much. So let’s give this a try. Just finishing up with my street tune and gonna be tuning WOT on the Dyno. What do you guys think I’ll make? It will be a dynojet. I’ll be dynoing on 91 and then on e85. You guys can guess both
99 ls1 (99 camaro short block)
Zo6 complete drivetrain (343 SP gears)
Ls7 lifters
Ls2 trays
Ls2 timing chain
Melling 295 pump
AHP ported Fast 92
Ported ls2 tb (98mm out/93mm in
Vararam ram air w/power duct
E2 catch can
Kooks long tubes
Kooks o/r x pipe
B&B bullet quad tip catback
Power bond 25% UDP
LPE 160 t-stat
Msd wires
Pro 5.0 shifter
Katech Billet tensioner
DRM Bilsteins
Pfadt/Johnny O’Connell Sway bars
Anti venom mod
Black smoked corner lights
Front bump steer
Rear bump steer
Alignment w/corner balance
Cometic MLS .040 Head gaskets
Zo6 maf w/adapter
LS6 Valley cover
Mototron 60 lb
Hi flow fuel rails
ARP head bolts
Holley red tall valve covers
Ls3 coils
LG tunnel plate
Pfadt engine mounts
Ecp aluminum radiator
Arp rod bolts
ls3 water pump
Rpm torque tube bearings and bushing
Spec mini twin clutch w/aluminum flywheel and Tilton slave
Tick master cylinder
Racetronix 255 fuel pump kit
IM Heatshield
DRM steering rack bushing
Proflex commander e85 system
C6 oil pan
TEA cnc tfs 215 heads ( titanium intake valves, 59cc)
.0070 ptv clearance
Yella terra 1.7 roller rockers
Anger management custom cam (236-238?, 113.5, .630)
fwiw...car weighs 3200 with me in it so it will be blast to drive when it’s all said and done !
Ls7 lifters
Ls2 trays
Ls2 timing chain
Melling 295 pump
AHP ported Fast 92
E2 catch can
Kooks long tubes
Kooks o/r x pipe
Power bond 25% UDP
LPE 160 t-stat
Msd wires
Pro 5.0 shifter
DRM Bilsteins
Anti venom mod
Front bump steer
Rear bump steer
Zo6 maf w/adapter
LS6 Valley cover
Mototron 60 lb
Hi flow fuel rails
ARP head bolts
Ls3 coils
LG tunnel plate
Pfadt engine mounts
Arp rod bolts
ls3 water pump
IM Heatshield
C6 oil pan
.0070 ptv clearance
I’m lovin’ your guess! Lol. This is rob zonas old setup on his black zo6. They guy who had it before me made 490/440 on a f body. If I remember correctly rob made 470 on a mustang dyno.
Pro Mechanic
