Possible hidden vacuum leak on Z51 after rebuild - where could it be?
Short background: Had my engine rebuilt with a stage 3 cam, new pistons, lt4 fuelling. Since it come back it idles like crap and often stalls. If I hold the throttle down a bit and get the revs up over 1000 it smooths out a bit, but anything below that and it just wants to stall. No CEL's. Tuner is Ben Charles - so well respected. He thinks there may be a vac leak as the tunes he has sent me have not remedied the stalling.
What I've tried: Sprayed carb cleaner around everything after the MAF. All visible vacuum hoses, the vac hose that plugs in behind the intake manifold, around the intake manifold port gaskets..etc. I've also tried removing my intake manifold (an MSD Airforce) and put the OEM manifold back on. If I create an intentional vacuum leak it doesn't make the engine run any worse than it does already. I am waiting on some smoke pellets to see if i can rig up a home made smoke tester. I've also tried disconnecting the MAF to see if the car runs any better in SD - it doesn't, it runs much worse.
Am I on the right track with a vac leak? Could it be anything else? Are there any VAC hoses that are not easily accessible/visible that could have been left unplugged when the engine was reinstalled?
Thanks guys.
Thanks guys.
Double check the intake bellows connection onto the throttle body. Had a car once where the lip folded under so it didn’t seal properly and let air into the intake that bypassed the MAF. Behaved exactly as you describe.
Thanks for the suggestion, but yeah I've looked there. If there is a vacuum leak I'm inclined to think that it is somewhere out of reach. Maybe a fuel injector gasket missing (although on a direct injection engine I'd imagine that would spray fuel everywhere), some kind of vacuum hose at the rear of the engine, or something much worse like something not bolted down properly inside the engine.
The only vac line that's hard to reach/see is the brake booster and I'm sure you'd know if that thing was loose. What about all of your pcv lines are they properly routed?
I tuned a 6th gen camaro that had an msd and a tight lsa cam with high lift and I was only ever to get it to around 65kpa at idle, which it wasn't very happy about. I had to make some pretty drastic changes to get the thing to run right. No vac leaks that I could find unless the manifold was cracked either...we never did get it on a smoke machine though.
I'm running an Mighty Mouse catch can with their recommended PCV routing:
Drivers side valve cover outlet > MM Can
2x Passenger side valve cover outlets > Dry sump oil tank
Intake manifold vacuum nipple > MM Can
Valley Port nipple (below the throttle body, on the engine block) > capped off
The only thing I have different to MM's instructions is this:
The nipple this breather is on was originally connected to the OEM air intake. So I don't think there should be an issue with it having access to open air?
Is there any chance the engine might not be firing on all cylinders? Would it be wanting to stall if that were the case? I suppose I can easily check that with a laser temp probe on the headers?
I'm Batman..
Pro Mechanic
there are no other vacuum lines other than the brake booster and PCV system that I can remember.
Received 5,217 Likes
I'm unclear, did you actually install the engine yourself? Doesn't sound like it, so what about your installer?. What does he think? Can he go over everything he did, step by step? Has he done an identical engine before? How does he work? I ask the latter because I've seen people who do things by halts and starts, constantly interrupted and returning to various projects which makes it easy to miss things.
In any event, all the best.
However, I've just dug myself into a WHOLE tonne of shi*t that makes me want to throw the whole project away.....
So I was checking the spark plug wires, and noticed that one of the wires to the plugs on the passenger side wasn't seating properly. I could slide the wire boot over the plug tip, feel it go into the metal connector inside the plug boot, but there was no 'click'. Tried it with a different spark wire and it was the same. It appeared to be an issue with the tip of the spark plug itself.
So I set about removing the spark plug, which was no easy task because the eBay exhaust headers I'd purchased got in the way of the spark plug hole! Eventually got it out, and set about installing the new one.
Threaded it in the first few threads by hand and then got a wrench on it. After a few turns it seized.....the plug was going in cross threaded!!!
This was enough to ruin the first few threads of the hole, meaning that I just couldn't get the plug to go in correctly no matter how many times I tried.
So I purchased a reverse thread tap. You put the tap in the hole, expand it with a screw and then tap the hole out in reverse so that it uses the good threads.
This happened:
Using only a small spanner, the tool broke apart inside the engine! I managed to retrieve 3 of the 4 pieces, but the fourth was inaccessible. I tried to vacuum it out, use magnets on sticks, but nothing could get close enough.
Eventually I got fed up and tied a magnet to a bit of string to try and fish it out of the cylinder - not realising that the cylinder walls are steel lined (i assumed aluminium). The magnet instantly stuck to the cylinder wall, and now I have two foreign objects in the cylinder that I cannot get out.
So I guess its time to pull the head....
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,822 Likes
2015 C7 of the Year Finalist
Post #9 brings tears to my old eyes! That is a major case of suck...
It would appear that you had found an issue with the plug and were on your way to recovery and then the
Good luck!
Elmer
Good luck!
Elmer
It seems like part of pulling the head also involves taking the water pump off and draining fluids. I am so bummed and I don’t even have a mechanically minded friend to help me
Oh, man, I hate to read stories like this. I learned a good cursing technique from a member of our old f-body group.... when you have a really crappy thing like this happen just just string every curse word you know into one long "sentence". Repeat as necessary. Good luck.
Nothing quite like the smell of success in the morning:
J
The silver lining here is that even if the tool hadn’t broken in the cylinder, the amount of metal shards from re-tapping the spark plug hole was enormous. And despite me vacuuming and using a magnet, there would have still been way too much shrapnel in there for my liking.
Now one I just need to wait for my head gasket to arrive and I can put this baby back together again
J
Excellent! Progress with my coffee this morning!
ELmer
ELmer
