Crossfire Fuel Pressure problem/question
Hi folks, so I have an '84 crossfire 4+3. I recently did a few 'minor' upgrades. Crank pulley upgrade, camshaft kit, headers, ported intake, exhaust. I am having a huge problem that I can't seem to solve. It is DUMPING fuel in from the throttle bodies. It is getting way to much fuel. I have done some adjusting to the rear 'controlling' throttle body (where you can adjust the spring in the center), I've also adjusted the idle screw and TPS. Buddy has a car with identical upgrades and I am doing my best to match his settings for everything. Initially, when connected to OBD1 reader it was not seeing input from the O2 censor. I ohm'd the O2 wire to the computer and bench tested the O2 sensor itself and everything works. I have not had the chance to connect the OBD1 reader since then. I also think the issue could be the MAP sensor.
Does anyone have any experience with these crossfires that could help me out? I should also add that I removed the A.I.R and EGR. Currently, the car will start up and idle, but idles up to 2500+rpm when correcting itself. Obviously not driveable. It's also hard to get the timing correct since the fuel is not right. Pull the plugs and they are soaked. Not sure whats going on. I have tried many things already. If anyone has suggestions I would love to hear them.
Thanks folks!
Thanks folks!
bad ground to ecm ... temp sensor ... ??
and fuel pressure is ??
try to disconnect cruise control wire
Pro Mechanic
CTS could cause your symptom....MAP unhooked could too. What's the fuel pressure set to?
2500 RPM + "lots of fuel"....sounds like a big vacuum leak, to me.
I didn't check the fuel pressure itself, its just very apparent that its way to much. I did put in a fuel pump from a 3rd gen F-body, upping the pressure a bit. Maybe that's the issue. But like I said, my buddy did an identical setup on his ride and we didn't see any issues whatsoever. I didn't think to try the cruise disconnect, I'll add that to my list of things to try.
Thanks for the interest, lots of good suggestions. I don't know exactly what the fuel pressure is. fairly confident its not a vacuum leak. If it is I don't know where its coming from. Sprayed starting fluid around intake gasket to make sure there wasn't any leaks there. And I would think you'd be able to hear it too, but I dunno. I'm still learning. Tom400CFI you mentioned CTS issue. What is that? Also, yes I should be able to hook up my reader to see what the MAP sensor is doing, once I get the scan tool back.
Pro Mechanic
fairly confident its not a vacuum leak. If it is I don't know where its coming from. Tom400CFI you mentioned CTS issue. What is that? Also, yes I should be able to hook up my reader to see what the MAP sensor is doing, once I get the scan tool back.
CTS is what Corvettenorway was talking about; Coolant temp sensor. If it's reading way cold, it'll make it way rich.
Ok cool, yah I know about the regulator, which is on the 1st (driver side) throttle body correct? with the spring that you can adjust? And I replaced or checked all the vacuum lines so I don't think that is the issue either. Could still be an option to look at thought. And I know about the Coolant temp sensor, I didn't put together that it was the CTS, my bad. I know I had an issue early where it just wouldn't start period because the CTS wasn't connected properly. They are probably cheap, maybe i'll just replace it and eliminate it being the issue.
Thanks again for all the suggestions guys. I'll try to get back in a few days and update you with any testing I've done.
get the right Coolant temp sensor for a 84
Pro Mechanic
