PKE off
Probably just turned off. Stand outside car (keys out of ignition), point fob at drivers door and hold down door button until you hear a clack clack sound. Should be working again, see owners manual.
Does the PKE lamp, light for 2 seconds when you turn the key to ON?
What did you do the fix the hatch problem.
Why did you revive a nearly two-year-old thread rather than continue using your perfectly good and active thread?
