C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] RPM VI T-56 or VII TR6060
Old 09-18-2018, 06:20 PM
Cash1333
Cash1333's Avatar
Default RPM VI T-56 or VII TR6060
Next year I plan on finally building my drivetrain. This may or may not seem a dumb question but I have an 06 Z06 and was trying to figure out if I should go built T56 or pay however much it is to convert and get a built TR6060.
Thanks
Old 09-18-2018, 06:55 PM
Millenium Z06
Moderator
Millenium Z06's Avatar
Depends on what you're doing. If you have plans on 900+ whp then go 6060; if not go T56
Old 09-18-2018, 07:27 PM
lamboworld
lamboworld's Avatar
You should check out Tick Performance. Much cheaper than RPM and just as good.
http://www.tickperformance.com/tick-...vette-z06-zr1/
Old 09-18-2018, 11:00 PM
73DBG
73DBG's Avatar
I can’t say enough of how awesome Matt at Tick Performance has been, dudes went way above and beyond what I’d consider great customer service! Eli is also solid hit them up you won’t regret it. Couldn’t tell you either way on which to use, seems like the rest of the forum has you covered though. I just can’t say enough good things about all my I interactions with Tick🇺🇸
Old 09-19-2018, 03:55 AM
Josh B.
Josh B.'s Avatar
I have a 2006 C6Z. I asked the same question about the T56 or TR6060. Many people warned that the "T56 shifts better, TR6060 is notchy". I wanted a performance 5th gear and that would have been difficult to achieve with the T56, so I went with an RPM Level VI TR6060 with C5Z gearing. I love the new trans, it shifts absolutely incredibly, no notchiness, just effortless shifts that make regular drivers into amazing drivers.
Don't overthink it like I did. Get the TR6060. You'll spend around $5k if you give them your core T56. Customer service is amazing. Call up Jeremy Jones and get a quote.
Old 09-19-2018, 08:48 AM
zaquhree
zaquhree's Avatar
i have the level 6 t56 with the 2.97 first and other shortened gears for 2 and 3. i love it!!
Old 09-19-2018, 11:15 AM
Detoxx03
Detoxx03's Avatar
Level VI 6060 here and I love it
Old 09-19-2018, 05:22 PM
MickVette
MickVette's Avatar
St. Jude Donor '13
Did you stay with the factory gear ratio in the rear end?
Old 09-20-2018, 05:11 AM
romandian
romandian's Avatar
is a tr6060 a bolt in?
Old 09-20-2018, 10:33 AM
Millenium Z06
Moderator
More or less, you have to fab up something for cooling.
Old 09-20-2018, 10:42 AM
Millenium Z06
Moderator
I have a T56 built built to level 5 and has a C6Z06 mainshaft and C5Z gears; shifts awesome and not notchy at all, no way you're missing a gear with the way it shifts.
Also has stage 3 C6Z diff.
I've heard that the 6060 doesn't shift as good but every one I've tried shifted fine. T56 is a little lighter so there may be some power gains there.
Old 09-20-2018, 12:08 PM
Josh B.
Josh B.'s Avatar
Yes I did.
Old 09-20-2018, 03:30 PM
MikeOC
MikeOC's Avatar
Are 5th and 6th paired together the way 1-4 are or are they individually selectable?
Old 09-20-2018, 03:31 PM
Josh B.
Josh B.'s Avatar
Pretty sure they are paired, like I got a .84 5th but they could only give me a .56 6th because of this, whereas I wanted the stock .50 6th.
Old 09-20-2018, 03:59 PM
MikeOC
MikeOC's Avatar
interesting, .56 is a lot more useful as a 6th than .67 at least
Old 09-20-2018, 07:34 PM
TRSCobra
Support Corvetteforum!
TRSCobra's Avatar
I got the .80 5th and kept the stock 6th with my 6060
Old 09-20-2018, 07:41 PM
Josh B.
Josh B.'s Avatar
I've been swindled yet again.
To RPM VI T-56 or VII TR6060
Old 09-20-2018, 09:43 PM
MikeOC
MikeOC's Avatar
.80/.50 sounds perfect, I'll have to look into that.
Old 09-20-2018, 10:04 PM
MTPZ06
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Lol. One day Josh...its gonna be payback time.
Josh B. (09-20-2018)
Old 09-20-2018, 10:18 PM
Josh B.
Josh B.'s Avatar
Gonna take the Miata for a drive after I take an upper decker
MTPZ06 (09-20-2018)
Quick Reply: [Z06] RPM VI T-56 or VII TR6060
