Wiper motor dead ?
Wiper motor dead ?
Hi,
I wanted to bench test my old wiper motor before putting it on the car, so I hooked up 12v to middle lead and grounded the case and top lead (fast speed) and all the motor does is click. I also tried to ground the lower terminal (slow speed) and still just clicks. Is this motor bad ?
Richard
Richard
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you followed this test, then yes the motor is dead.
1973-1982 Wiper Motor Testing.
[QUOTE=Willcox Corvette;1598017989]If you followed this test, then yes the motor is dead.
Yep, your test is what I followed.
Thanks again for your great write-ups & videos
Richard
Richard
Former Vendor
[QUOTE=Willcox Corvette;1598019097]
I did, I hooked a clip to the case and clipped it to the same lead that was grounding the high-speed pin which went back to the battery negative terminal. I just clipped on the case(see the black clip on the case in my first pic), I assumed any part of the case is good, am I correct ?
I just didn't understand what would just cause it to click, I expected it not do anything at all or work, but not to just click...
Richard
Richard
The click is the parking relay moving. Good luck finding a motor that will work for more than 6 months. I'm on my second one and am looking at alternatives to buying crappy Chinese junk motors that are sold today. I can't afford $100 every 6 months to have reliable wipers. My car is my daily driver right not so I need reliable wipers.
Another thing, does your power supply have enough current to turn the motor? I use my car's battery for my 12v source even though I have a 12V power supply on my bench but it only puts out an amp. I don't think that is enough to get the motor started.
Former Vendor
I also sell rebuilt originals if you'd like to try one of them instead of the LL reproduction.
And you are correct, most smaller power supplies don't have the amperage to run these motors, so for the home repairs it's simpler to just use the voltage from the car itself.
Andies,
Thanks as always.......Willcox rules!!!!
Former Vendor
Then when you buy one you receive it, send in the original core and It keeps the cost down. It's cheaper for me to do this than to take the time myself and rebuild them... but they have a great track record with us too.
We've probably got one on the shelf, I don't know what year car you have or I'd check. All you'd need to do is send in the core to us after you received the motor. https://willcoxcorvette.com/catalogs...iper+motor+reb
Ernie
thanks for for the info on the parking relay. Yes, I was using my car battery for the source. I think i will go the rebuild route also if Wilcox had a rebuilt one for a 1980.
richard
