FS: Car Audio equipment
Car Audio equipment
Alpine Type R 600 watt 6x9 Speakers (SPR-69C) - SOLD
Condition: Purchased but never used.
These speakers are very nice and have HUGE bass blockers built into them and hold quite a bit of power.
Alpine MRV-M500- SOLD
500W V-Power Series Class D Monoblock Digital Amplifier
Condition: Used for 6 months and not needed any longer. Was in my c5 z06 and sounded great.
Comes with the optional Alpine RUX-****.2(remote bass ****)
Alpine SWT-10S4 - $100obo
1000W Peak 10" SWT Series Single 4-ohm Shallow Mount Subwoofer
Pioneer DEH-1300MP - SOLD
In-Dash CD, MP3, WMA Car Stereo Receiver with Front Aux Input and Remote Control
Condition: Used, not needed any longer.
In-dash AM/FM, CD, CD-R, CD-RW, MP3, WMA player
Rockford Fosgate RFR3112 12" Power HX2 – SOLD
2,000 watt subwoofer, dual 2 ohm so you can run a 1 ohm load or a 4 ohm load. Subwoofer is very heavy and it will handle a lot of power.
Condition: New, speaker is no longer needed and has just been sitting in the box and has not seen any power whatsoever.
- Type-R, 6x9 2-way Speakers
- Power Handling:
- Peak: 600 watts per pair / 300 watts each
- RMS: 200 watts per pair / 100 watts each
- Impedance: 4 ohms
- Full low-frequency response with hybrid layered-pulp woofers
- Premium silk ring-dome tweeters
- 1" swiveling silk ring-dome tweeter
- Rubber surrounds
- Frequency Response: 60 Hz - 27,000 Hz
- Sensitivity: 89 dB
- Top-mount depth: 3"
- V-Power Series Class D Monoblock Digital Amplifier
- RMS Power Rating:
- 4 ohms: 300 watts x 1 chan.
- 2 ohms: 500 watts x 1 chan.
- Max power output: 500 watts x 1 chan.
- Integrated wire and mounting screw terminals
- S.T.A.R. circuitry
- LED power (blue) and protect (red) indicators
- Variable Bass Boost (0 to +12 dB bass boost at 50 Hz)
- Soft start turn-on
- 4 or 2 channel operation
- 4-channel speaker-level inputs
- Preamp RCA outputs to daisy chain multiple amps
- 3-way protection circuitry (thermal, overload, and speaker short protection)
- Dual speaker terminals simplify the hookup of multiple speakers
- Heavy duty aluminum alloy heat-sink
- Input sensitivity: 0.4V - 10V
- Non-fading pre-amp output
- Variable low-pass filter (50-400 Hz, 24 dB/octave)
- CEA-2006 compliant amplifier
- Dimensions: 7-7/8"W x 7-7/8"L x 2-3/16"H
- 10" SWT Series Single 4-ohm Shallow Mount Truck Subwoofer
- Power Handling:
- Peak: 1,000 watts
- RMS: 350 watts
- Recommended Power Range: 100W - 350W
- Poly-Mica Dust Cap & Pulp-Kevlar
- Polyurethane Foam Surround
- H.A.M.R. Surround Technology
- Spiral Cut Aluminum Former
- 65mm Voice Coil with High-Temp 4-Layer SVC Winding
- 8AWG Push Terminals
- Top-mount depth: 4-3/16"
- Mounting Diameter: 8-15/16''
- Frequency Response: 30 - 200 Hz
- Sensitivity: 84.8 dB
- Detachable face
- Single line text LCD display with 8-character text
- Large rotary volume control is simple to use
- Red button lighting
- New pioneer anti-dust design
- Power Output:
- Peak: 50 watts x 4 channels
- RMS: 22 watts x 4 channels (Pioneer Rated)
- RMS: 14 watts x 4 channels (CEA2006 Certified)
- CD Text Display
- MP3 ID3 Tag Display (Title/Artist/Album)
- FIBERlock treated paper cone with Santoprene™ rubber surround
- Frequency Response: 26-400 Hz
- RMS Power Handling: 1,000 watts (500 watts per coil)
- Peak Power Handling: 2,000 watts
- Sensitivity: 85 dB
- Dual Voice Coil Design (two 2-ohm voice coils)
- Top Mount Depth 6-7/8"
- Sealed Box Volume: 1.00 cubic feet
- Ported Box Volume: 1.75-4.0 cubic feet
