EFI Fuel Tank
EFI Fuel Tank
Since I now have a F.A.S.T. EFI on my 1966 with zz502 it was recommended that I also should upgrade my tank to an EFI version. Can anyone give me a rundown on install tips? Such as removing my existing tank? What I currently have; original style tank with external electric fuel pump and want to install the EFI style tank with internal pump, no spare tire carrier and side exhaust. Is there a good vendor that sells everything in a package for this conversion?
I went with a Tanks Inc fuel tank with in tank pump and fuel sender that works with a C2 gauge and I think it was +$600. Summit sells their stuff so I was able to use a 10% coupon to bring the cost down a little more. All you need to do is run power to the pump and plumb your fuel lines. I think Holley sells their tank for there EFI systems now.
I used Ricks on my Restomod, all SS with a pump ~$1000
I saw the Tanks Inc. when I was searching Google. Appears to be an all inclusive kit. I already have an inline pump at the rear of the car and a return line so that will make it easier. I'll look into it a little further.
Rustman, how did you snag a 10% off coupon at Summit?
You also have to be careful plumbing the lines to the tank on C2s, at least with the Tanks Inc tank. There was no room for me between the tank and the body to take the line forward like in the above picture. I ran flexible lines reward and to the right to where the original fuel line was.
Why do you need a special tank for a Fast Injection system? Can you just run am internal pump in the standard tank?
I don't think you absolutely need a special tank for EFI, but I was needing a new tank so I opted for this one. As a plus it comes with baffles and a pan to allow for gas to stay around the pump pick while cornering and such. I know others have installed intake on their old tanks.
https://fitechefi.com/products/47012/
St. Jude Donor '07
Rock Valley SS fuel tank with internal pump in my '66 with Holley Sniper EFI
Bill
Oops.........
I probably should have been more clear. I have a C2 and have a new tank (never had gas in it) stock with vent I plan to use for the return. I am looking for something to mount in the bottom pointed up like the stock setup but of course I have to keep it for the sending unit. Trying to avoid having to buy another tank. Don't mind drilling this one because it has never had gas in it yet. Thx
Easy.......
Taking a C2 or C3 tank is pretty straight forward after you get around the mufflers. Take filler neck off before dropping tank for extra clearance to top compartment. This is for roadster I have not done a coupe.
I am still looking to purchase the Tanks Inc. kit but it will come down to who has the better deal. I also need to figure out which in tank pump to get. I have a zz502 (502 hp), pump pressure at 42 psi and high output alternator. When I get around to doing this the only thing that I don’t know about is removing the filler neck before taking out the tank.
