Offset of those running 19x11 rear wheels and 305 tires
I'm planning to order 19x11 CCW 505 rear wheels and 305/30/19 tires. I'm trying to figure out the best offset to keep the setup from sticking out of the fenders (if possible) but not rubbing the suspension or wheel wells. What offset are you guys using? I'm thinking 62mm. Will that work? Also any pics of your setup would be great. FYI, I have a 1997 Coupe.
The popular offset for those exact wheel/tire sizes in the Forgestar offerings is 55mm. Mine is below. The fitment is flush. I believe CCW uses a slightly less aggressive offset, so 62mm would be a good bet. Honestly, just let CCW pick the offset. They have done a gazillion C5s.
The following 2 users liked this post by FYRARMS:
CorvetteBrent (09-21-2018),
tdf01cycling (09-26-2018)
Received 1,261 Likes
JETZ (09-21-2018)
Looking verrrry Sano indeed. Maybe it's 'the' BLUE.
You need to paint those wheels ALL black, and git ye some dem 'calibration covers'. Nowatimsayin? (Why do people do that?)
frank
frank
So an offset on one wheel manufacture is not necessarily the same as for another? Let's say a by a Cray wheel with a 58mm offset and a CCW with a 58mm offset. Could the have different backspacing even though the offsets are the same?
Will look up the specs on my CCW SP16a and post it later this morning. Rears have 2" lip with 305's that do not stick out and wheels will accept a big brake kit.
Specs for my CCW SP 16a wheels
Fronts - 19" x 9.5" with 7.30" backspacing and an offset of +52 with a 1" lip
Rears - 19: x 11" with 8.15" of backspacing and an offset of +64 with a 2" lip
Running Michelin PSS 265/30/19 fronts and 305/30/19 rears. They do not hang out.
Wheels were designed around a future big brake kit working with them.
Hope this helps. Good luck with your choice of wheels.
The following 3 users liked this post by 02BlownZ06:
Wheels are offered in every offset imaginable, depending on the vehicle they are designed for, the actual wheel design, brake clearance, etc. Just like car manufacturers offer different colors than each other, wheel companies use different offsets.
Assuming they are the same width wheel, no. That isn't how it works. Offset and backspacing are both just different types of measurement. For example, two different pieces of spaghetti that are both 25.4mm long will both be 1" long. They can't be different lengths.
Both my 19's & 20's have 8.650 backspacing the tires on my 19's were about 1/4" overhang past the rim & with -.5 neg camber had about 1/8" poke.
The tires on the 20's are under 1/8" past the rim & with same camber only poke 1/16" the picture with the stick had more camber than I have now, around -.9
1st picture is 19's 2nd & 3rd are 20's
Forgot to add that I have what CCW calls 2" lip, I measured the rears & were about 2-7/16" most of the 3" lip I have seen poke a lot more unless you run more camber.
Received 1,868 Likes
