How do I remove
BLUDICE (09-22-2018)
Put the tip of a small flathead or tip of knife in the bottom of the front and gently pry up, it will pop right off. Just wrapped mine the other day with some 3D CF vinyl I had left over from another projects.
BLUDICE (09-21-2018)
You have to remove the airbag first by inserting a screwdriver in a small hole on each side of the steering wheel and pulling out on the airbag, then that exposes the screws that hold those silver pieces to the steering wheel. Lookup a youtube video for C6 steering wheel removal and use that for guidance. Just make sure you disconnect your battery first!
Received 2,887 Likes
I suggest you bookmark Paul Talons website of tech tips for the C6.
http://www.theredlion.us/Tech%20tips2.htm
The following 3 users liked this post by wayback:
