Disconnecting the battery for storage
I live in Minnesota and its getting to be that time where I'll need to send the car into storage. I own a 2017 C7 convertible & one of the storage companies I'm considering doesn't let you take the battery & doesn't have available outlets to plug it into a battery tender. So, what they do is just disconnect the battery. My question is - besides having the default settings in the radio & seat preferences reset, does disconnecting the battery for 6 months pose any major problems?
To be clear, it is a temperature controlled environment. They keep it at about 45-50 degrees through the winter. Thanks for the replies!
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Nope...
Regards
Chip
Zisca14 (09-24-2018)
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,400 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
Moderator
Anybody that knows anything about proper lead acid battery care will tell you that these batteries always need some sort of maintenance charging system connected or they won't last long. Look it up and research it. There are lots of write ups on lead acid battery care. Pull the battery yourself and put it on a tender.
Received 1,738 Likes
St. Jude Donor '15-'16,'18
I would find another option for storage. You definitely want to keep the battery on a maintainer. Several months will lead to a completely dead battery.
Received 1,762 Likes
ttt
Put a tender on it for the c7 is all you need to do here.. Robert
If you can't 'remove' the battery yourself and take it home for storage and charging I wouldn't store your C7 with them.
The following 3 users liked this post by Kevin A Jones:
I am from Wisconsin and have stored my "toy" cars over the winter in an unheated environment with no electricity available for decades. As stated before, you cannot just unhook your battery, leave it over the winter in the Minnesota cold and expect to use it again. It will lose charge and freeze over the winter. At that point it will be junk.
Received 5,188 Likes
May I suggest speaking with other specialty car enthusiasts in your area and see what they typically do over the winters. I agree, you DON'T want to do as you have stated. Also, if by some slight chance a frozen battery cracked, I don't think you'd like it.
The following 2 users liked this post by Avanti:
Kevin A Jones (09-23-2018),
Moderator
https://batteryuniversity.com/learn/...tore_batteries
I copied and pasted the below paragraph:
"You can store a sealed lead acid battery for up to 2 years. Since all batteries gradually self-discharge over time, it is important to check the voltage and/or specific gravity, and then apply a charge when the battery falls to 70 percent state-of-charge, which reflects 2.07V/cell open circuit or 12.42V for a 12V pack. (The specific gravity at 70 percent charge is roughly 1.218.) Lead acid batteries may have different readings, and it is best to check the manufacturer’s instruction manual. Some battery manufacturer may further let a lead acid to drop to 60 percent before recharge. Low charge induces sulfation, an oxidation layer on the negative plate that inhibits current flow. Topping charge and/or cycling may restore some of the capacity losses in the early stages of sulfation. (See BU-804b: Sulfation and How to Prevent it.) "
Received 3,288 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Why won't the storage place let you take the battery out and keep it with you on a maintainer? Requiring it to stay in the car but letting you unhook it makes no sense.
[QUOTE=Steve_R;1598040914]Why won't the storage place let you take the battery out and keep it with you on a maintainer? Requiring it to stay in the car but letting you unhook it makes no sense.[/QUOTE They store about 400 cars and as cars come in they need the ability to move the cars around to make the most out of the space. So, I guess the bottom line is that they need to be able to move it around the facility. I think this has more to do with moving the cars out of the facility in the spring as you have to give them a 5 day advance notice of when you plan to pick up the car. Keep in mind these are not individual stalls. Instead it is several open floors of cars - bumper to bumper & door to door essentially.
I store my C7 from Jan-April in a unheated garage where temps drop well below freezing in Southern Ontario. We head to Florida during that period. I charge the battery up with a tender for a day, then I disconnect the positive lead (leaving the battery in the car). In April I reconnect the the positive lead and put the tender on for a day before I start it. In 4 yrs no issues at all. I have another 12 yr old sports car that I have done the same thing with, no issues. I actually take the C7 off the road in early November but periodically put the tender on it for Nov and Dec. before we leave for the south. It takes a temp of -92F to actually freeze a charged lead acid battery.
Battery Basics
Battery Basics
In that temperature, if you disconnected the battery after fully charging it, and it sat for 6 months, it would probably have a charge and still work in spring. The below confirms this. If you don't want to read it all skip to the summary bullets at the bottom of the article. It says that once it self-discharges below 70% you should really re-charge it (actually 2.07 volts per cell of 12.42 volts for most lead acid batteries).
" Why won't the storage place let you take the battery out and keep it with you on a maintainer? Requiring it to stay in the car but letting you unhook it makes no sense. "
That is, unless they also sell batteries!
Moderator
