Question about 02 sensors
Old 09-22-2018, 04:21 PM
Los Jr
Los Jr's Avatar
Default Question about 02 sensors
Context: I have Long tubes, 2 rear 02's were deleted and tuned out in the ecm. passenger side front 02 has gone bad, throwing no activity code and showing erratic switching in logs.
My B2,S1 02 has gone bad recently, but I read somewhere that all of the 02's are heated 4 wires. I have Long tubes and wanted to ask if I could use one of the 2 deleted 02's that I have sitting in my garage to replace the one that went bad. I searched the board, but when I use the advanced feature to search for "02 sensor" it removes "02" from the search.
Thanks for the help in advance y'all
Old 09-22-2018, 05:56 PM
neutron82
Support Corvetteforum!
neutron82's Avatar
Received 1,261 Likes on 1,056 Posts
you can but the plugs are different, you will either need adapters, repin the connectors, or cut off the connectors and wire them to your old sensors
Los Jr (09-22-2018)
Old 09-22-2018, 06:44 PM
Los Jr
Los Jr's Avatar
Ok Cool, I can re-wire/solder them to the harness from the bad one. Thank you for the response!
Old 09-26-2018, 01:38 AM
striper
striper's Avatar
You can just buy new replacements reasonably on Amazon, no soldering necessary. Bosch recommended. Or Rock Auto.
To Question about 02 sensors
Quick Reply: Question about 02 sensors
