Harmonic balancer????
Old 09-22-2018, 09:37 PM
twynia
twynia's Avatar
Default Harmonic balancer????
2007 c6 z51 45k miles.
Harmonic balancer?
Taking to dealer Monday about a 15 to 20 min drive, is that drive advisable? Noise just started today
Old 09-22-2018, 10:36 PM
buckmeister2
buckmeister2's Avatar
Received 1,206 Likes on 824 Posts
Yes, you are safe. There is a lot of fret and worry over the HB, but it will not grenade on you, unless it is really bad, and you are racing. Lots of people drive 100K with wobble (not noise) with no worries.
Old 09-22-2018, 11:52 PM
twynia
twynia's Avatar
. Thanks
Old 09-23-2018, 08:34 AM
Dman302
Dman302's Avatar
get it fixed sooner than later, mine shifted and caused the belt to squeal then it tore apart....the debris hit my ac wire connection and destroyed it. That is a one pc clutch/connector for the ac and added another $400 to the price of the balancer.
Old 09-23-2018, 08:49 AM
Dano523
Dano523's Avatar
Received 3,001 Likes on 2,166 Posts
The noise your hearing is coming from the belt tensioner. So when the HB is being replaced, make sure that at least replace the tensioner pulley with bearings, or the entire tensioner as well.
As for dealer, unless they can install a Power bond PB117SS (not another oem HB or the power bond PB117N) then would for another shop that will install a Power bond PB117SS. Hence the OEM, and the power bond PB117N which is just another copy of the OEM, will have the same problem about the same mileage as when the first HB gave up the ghost.
On the SS unit, it has a fange on the back side, C ring on the front side, both which sister the outer pulley to the inner hub, which prevents the HB from wobbling in the first place, and later as well.
Old 09-23-2018, 10:28 AM
windyC6
windyC6's Avatar
I realize that a belt tensioner can make a noise....but it was my understanding that the "TYPICAL" squealing that accompanies "MOST" of these H/B issues is due to the belt rubbing against the side of the pully........
Old 09-23-2018, 11:59 AM
Turbo6TA
Turbo6TA's Avatar
Received 3,065 Likes on 2,072 Posts
I just had a local performance shop here in Florida install a new harmonic balancer on my 2011 GS.
I also had the HB pinned since I will be installing a supercharger myself.
This can give someone here an idea of what I paid:
$ 223 . . . . . PowerBond Race Performance Harmonic Balancer . . (P/N: PB1117SS)
$ . 93 . . . . . ARP Crankshaft Bolt, GM Timing Cover Seal and Pinning Kit
$ 593 . . . . . Labor Charge with Tax . . (Labor is taxed in Florida)
_____
$ 909 . . . . . Total Cost
Old 10-02-2018, 01:56 PM
tonyb47
tonyb47's Avatar
Harmonic balancer?
what kind of noise are you getting, I'm getting a squeaking noise, changed both belt tensioners, both belts and the idler pulley and still have it. The previous owner replaced had the Hb replaced and gave me the receipts, i'm at a lost
Old 10-02-2018, 02:35 PM
Turbo6TA
Turbo6TA's Avatar
You need to look at the balancer when the engine is idling.
If it's wobbling, you need a new balancer ... simple as that
Old 10-02-2018, 02:46 PM
HBsurfer
HBsurfer's Avatar
Received 1,105 Likes on 706 Posts
If the replacement balancer was a GM part, it could already be bad again. Take a look and see if it is wobbling. Some here have replaced a GM balancer in as little as 4,000 miles and several have replaced it more than one time. If you need a balancer again, buy an aftermarket part like Powerbond or ATI.
Old 10-02-2018, 02:51 PM
theandrewo
theandrewo's Avatar
If the previous owner replaced with the OEM balancer then it could be going bad again. The OEM HB is trash. Upgrade to an aftermarket that won't go bad.
John 511 (10-02-2018)
Old 10-02-2018, 03:02 PM
Turbo6TA
Turbo6TA's Avatar
If you need a new balancer (and one that will last) ... Here:
https://www.summitracing.com/parts/pbb-pb1117ss
Old 10-03-2018, 09:36 AM
tonyb47
tonyb47's Avatar
I will check it out, Theres only been 3000 miles on it since it was replaced. That was the last thing I thought of checking. Do they make a squeaking noise similar to belt tensioner going bad
Old 10-03-2018, 09:38 AM
tonyb47
tonyb47's Avatar
Are all years of C6"s affected by these crap HB'S
Old 10-03-2018, 09:56 AM
Turbo6TA
Turbo6TA's Avatar
Yup ...
Old 10-03-2018, 09:06 PM
ErikR
ErikR's Avatar
This is what my '07 with 36,000 miles sounded and looked like. I was replaced with an ATI... total was $900 parts and labor.
This is what it's like now!!!
The following 2 users liked this post by ErikR:
bonnell (10-05-2018), DRKCYDE (10-06-2018)
Old 10-03-2018, 09:33 PM
Turbo6TA
Turbo6TA's Avatar
Erik ....
Great example !
The following 2 users liked this post by Turbo6TA:
bonnell (10-05-2018), tonyb47 (10-04-2018)
To Harmonic balancer????
Old 10-04-2018, 09:52 AM
tonyb47
tonyb47's Avatar
https://www.youtube.com/watch?v=Hn_Y2uyxHfM
https://www.youtube.com/watch?v=8l1RcDRtBxw
thanks for video, that was great
Old 10-05-2018, 08:08 AM
BLEKVET
BLEKVET's Avatar
I also recommend ATI SuperDampr. You can go with a slight under drive as well without affecting your accessories while increasing rev response You can purchase from LG - they will recommend the correct unit with ARP bolt. Any dealer known for decent Corvette sales and support will have a guy that can do the install and pin the crank. With a new gates green series belt, you are all in just under $1,000
Old 10-06-2018, 03:10 PM
RobJoy
RobJoy's Avatar
When it comes off it can do a lot more damage by the serpentine belt slinging around and the balancer grinding against the cross member than the $75 or so the rollback will cost. I put an ATI balancer on mine when I did a cam job.
Quick Reply: Harmonic balancer????
