C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
LS7 MAF IAT Breakout - Temp Rescaling?
Old 09-22-2018, 09:50 PM
Creamo3
Creamo3's Avatar
Default LS7 MAF IAT Breakout - Temp Rescaling?
I purchased the ECS PNP IAT breakout kit for the LS7 maf and it appears they use an LS1 push in style IAT. After installing I'm seeing that IAT's are reading ~15* cooler than ambient and prior to doing the breakout I would see IAT's close to ambient when cruising. Do I have to rescale the IAT Sensor Cal and if so, does anyone know the resistance/temp scaling for that sensor?
IAT Sensor P/N: 5029 / 4A (Push-in style)
Old 09-23-2018, 06:53 PM
lt1z
lt1z's Avatar
If you change the IAT it needs to be rescaled. I use an IAT2 sensor from and LSA/9 on most LS3/7 applications when breaking out the IAT from MAF
Old 09-23-2018, 07:24 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Same.
Find an application that uses that sensor from the factory and copy the data from the factory tune.
CI GS (09-23-2018)
Old 09-23-2018, 08:05 PM
Creamo3
Creamo3's Avatar
Thanks for the responses. I'd like to use the sensor they sent so that I don't have to pay twice and just rescale for that style. I did some quick searching for LSA/LS9 IAT2 sensors, but I'm seeing all threaded versions. I've already got the grommet installed for push-in style, do they sell those sensors in that style? I'll probably weld a bung over the winter but looking for a quick solution. Otherwise I'll just adjust the current temp scale to read closer to what it was before.
Old 09-24-2018, 08:06 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
If it's the sensor I think it is I'd pull the data from a GTO, but without seeing it I'm not sure. I couldn't find the part number you mentioned earlier. I have the push in style on mine but without seeing it can't tell if it's the same. The metal threaded ones seem to heat soak a little more. I had one of those originally but switched to the push in/grommet style one
Creamo3 (09-24-2018)
Old 09-24-2018, 08:42 AM
Creamo3
Creamo3's Avatar
Here's an image that I snapped of the sensor, I'll have to double-check but didn't cars that utilize this sensor reference %, whereas it's measured as resistance in the E38?
Old 09-24-2018, 10:29 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Weird, I've never seen that sensor before.. hopefully someone else can help
Old 09-24-2018, 11:26 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
I have a push in one, but it is the OEM caddy push in one. Looks nothing like that.
Old 09-24-2018, 11:49 AM
gameover4
gameover4's Avatar
not to state the obvious but give ECS a call. they will be able to tell you exactly what to write .
Old 09-24-2018, 11:50 AM
lt1z
lt1z's Avatar
Maybe ECS can tell you what to do since they supplied it.
To LS7 MAF IAT Breakout - Temp Rescaling?
Quick Reply: LS7 MAF IAT Breakout - Temp Rescaling?
