ccm question
Old 09-22-2018, 11:10 PM
polo91
polo91's Avatar
Received 1,031 Likes on 482 Posts
Default ccm question
I need to replace my CCM on a 91 roadster. Will my keys still work?
Old 09-23-2018, 10:13 AM
WVZR-1
WVZR-1's Avatar
Received 2,263 Likes on 2,026 Posts
If you're using a 'USED" CCM it would have to have the same VATS reference embedded in the programming. It would be a coincidence. Also if using a 'USED' the mileage displayed on the dash would be the mileage from the 'donor' car and if scanned it would also display the VIN of the 'donor'.
You didn't mention REMAN or USED so you might start with mentioning what you've bought or anticipate buying. Learning VATS to a REMAN requires all of the current keys that you have, programming miles and entering the VIN.
polo91 (09-23-2018)
Old 09-23-2018, 01:10 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
If you are replacing the ECM while using the OEM Prom you will have no problem with key code.
Old 09-23-2018, 01:20 PM
WVZR-1
WVZR-1's Avatar
OP is replacing CCM NOT ECM - PROM and ECM aren't relevant!!!
Old 09-23-2018, 02:52 PM
polo91
polo91's Avatar
I had planned on buying a used one, but it sounds more complicated than what I thought. The reason for the replacement was that the fuel gage doesn't work. I ran the diagnostics as the shop manual chart shows and the result is "replace CCM". I think I will just keep filling it up every 250 miles and check on getting my CCM rebuilt.
Old 09-23-2018, 03:27 PM
WVZR-1
WVZR-1's Avatar
Always 'FULL' - always 'EMPTY' or just 'INACCURATE' ?
Old 09-23-2018, 07:36 PM
polo91
polo91's Avatar
Always empty.
Old 09-25-2018, 10:38 AM
scotth48
scotth48's Avatar
Always empty.
I would pull fuel pump and tank float out of fuel tank. The fine wires on the gauge mechanism may need to be cleaned. Also float may have come off or stuck.
polo91 (09-30-2018)
Old 09-25-2018, 11:09 AM
Jitsu
Jitsu's Avatar
Have you ran a bottle of Techron thru the gas tank? I’ve had fuel sending unit inaccuracies and after running thru a full tank of gas w/ a bottle of Techron it worked normal.
polo91 (09-30-2018)
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
I would hope that "the diagnostics" would include checking the float assy...but I'd probably triple check everything as CCM's don't fail very often.
polo91 (09-30-2018)
Old 09-30-2018, 06:34 PM
polo91
polo91's Avatar
I put about 10,000 miles a year on the car and put Techron in about every 4 months.
Old 09-30-2018, 08:42 PM
polo91
polo91's Avatar
Sometimes you have to be smarter than the Shop Manual. The diagnostics does not mention the float, but all was well when I replaced the fuel pump a couple of years ago. I pulled the sending/pump unit a few minutes ago and found the scraper wire was not touching the resistor. That has been corrected and all is well. Thanks guys you saved me about $300 and the disappointment when the CCM would not have fixed the problem. This forum has been a big help for me for the last ten years.
Old 09-30-2018, 10:03 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Old 10-01-2018, 09:23 AM
WVZR-1
WVZR-1's Avatar
It certainly seems 'odd' the FSM is assuming that the fuel sender is operating. A meter and checking the 'PURPLE' wire for continuity & also value I believe should be a 1st check. A later year which of course is a bit more sophisticated actually hints the first check is 'sender' & IP comparisons.
Old 10-01-2018, 07:00 PM
polo91
polo91's Avatar
Originally Posted by ihatebarkingdogs
I read the troubleshooting flow chart for "gauge reads empty" again. My 91 book, page 8A-82-15 Chart #12.
First step is disconnect fuel tank unit: Does gauge now read Full? Yes = Replace fuel tank sending unit. (This is CLASSIC behavior for the old analog system. Open circuit = FULL).
No= Connect test light between connector terminal and ground.
Is test light "ON"? Yes = "Replace CCM". (There isn't enough current at 5V from the CCM to light a 12V test light. (again, this is for an analog system that operates at 12volts).
No= Check for short to ground. (This is the only correct branch of the chart. A grounded purple wire will indicate FULL).
So they check the sender in the first step, and if the state of the gauge changes they say change the sender. But the inference open circuit = FULL, is NOT correct for the 1991 Corvette.
This chart is DEFINATELY written for the old analog dual-coil gauge. Not the 5V CCM system.
Exactly right, very misleading, if it wasn't for people that know something on this Forum, I would have spent a lot of time and money and still missed the problem, Thanks guys.
To ccm question
Quick Reply: ccm question
