Is this hose supposed to be “flat”?
Old 09-23-2018, 01:55 PM
STRMLNE
STRMLNE's Avatar
Default Is this hose supposed to be “flat”?
Is that how is it supposed to look? Thanks.
Old 09-23-2018, 02:23 PM
STRMLNE
STRMLNE's Avatar
Circled what I’m referring to
Old 09-23-2018, 02:35 PM
Exact1
Exact1's Avatar
Originally Posted by 8VETTE7
I can't tell from your picture but it is the upper radiator hose and if the side of the hose are sucked in together then you have a failed pressure cap on the surge tank. Get a replacement, top off the coolant and then bleed the air that will be trapped in the cooling system as a result of the failure.
The pressure cap on the surge tank acts like a two way valve. When the coolant is rising in temp above 212* it closes off to allow pressure to build on the cooling system and as the coolant drops down under 212* it opens up to allow atmospheric pressure back in on top of the coolant. If the cap fails to let air back in then a vacuum is formed inside the cooling system resulting in the hose sides being sucked together and the air that should remain on top of the coolant to be sucked into the engine. Hence the need to bleed the system if this failure has occurred.
Very good information!
Old 09-23-2018, 02:50 PM
STRMLNE
STRMLNE's Avatar
Thanks. I just picked the car up from the dealer after having the water pump replaced. They had to drain the coolant and replace as part of the repair. Looks like something went wrong. It’s impossible to find a good repair shop these days.
Old 09-23-2018, 03:15 PM
STRMLNE
STRMLNE's Avatar
Had a very loud squealing noise when car was cold. Dealer told me water pump was leaking onto the belts causing noise. Water pump was replaced. And yet I still have the noise albeit it’s slightly quieter. Car going back tomorrow.
Old 09-23-2018, 04:11 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Whatever happend to a real mechanic that can diagnose? Todays version is some "me too" parts changers that guess and learn at your expense.
Spent years and over 3k chasing a code turned out to be a fuse from jump starting someone the whole time. Pizzed.
Old 09-23-2018, 06:53 PM
c4cruiser
c4cruiser's Avatar
FWIW, if you are going to replace the pressure cap, there is an upgraded version that's rated at 18 psi. The AC Delco part number is RC87 and the GM part # is 25713160. I picked one up for my '02 from
Amazon Amazon
for under 10 bucks.
Old 09-23-2018, 06:55 PM
STRMLNE
STRMLNE's Avatar
You were correct. Hose now looks normal after it warmed up. Thank you.
Old 10-19-2018, 04:17 PM
STRMLNE
STRMLNE's Avatar
Thanks! The dealer found the radiator cap failed exactly as you said and replaced it. The issue is gone. Thanks again.
To Is this hose supposed to be “flat”?
Quick Reply: Is this hose supposed to be “flat”?
