LED Taillight Bulbs
LED Taillight Bulbs
I would like to swap out the standard taillight bulbs on my ‘99 FRC for LED bulbs. Am I going to run into problems by just pulling out the present standard bulbs and replacing them with the new LED bulbs with no other modifications. I have already replaced the headlights, reverse lights, and license plate bulbs with LED’s. I don’t want to go the whole conversion route - just bulb swaps!
St. Jude Donor '17-‘18-'19-'20-'21-'22-'23-'24
You will probably need a hyperflash harness so that your turn signals will flash at the normal rate. Relatively inexpensive and easy to install. In fact, forum vendor RadioFlyer has a sale going on now through the end of the month.
If you start getting service traction control/active handling error in DIC after putting LED tail lights in, might want to look into this:
https://www.corvetteforum.com/forums...-handling.html
ArmchairArchitect (09-25-2018)
