Need blinker fluid?
09-25-2018, 01:24 PM
Need blinker fluid?
Ok seriously I know there's no such thing as blinker fluid but I do need help with my blinkers.......when I got the car when blinker work and one blinker stay. So I changed all four tail lights and my blinker fuse now my blinkers do not blinker at all whatsoever but they do get power to so I can push up on the direction I'm turning in the light Will stay on...... and I also thought it was strange that it didn't affect my hazards my hazards work properly
09-25-2018, 02:23 PM
Assume that one side (left or right) works and the other does not?? Could be a bad turn signal flasher. The hazards have their own flasher.
09-25-2018, 02:39 PM
You only need blinker fluid if your car has piston return springs.
09-25-2018, 05:57 PM
I changed the air in my tires because fresh air is better. My turn signals are much brighter now.
09-25-2018, 07:26 PM
C4 of Year Finalist (appearance mods) 2019
Quote:
Originally Posted by
AgentEran
I don't think that's totally correct. If for example you have an L98 with muffler bearings, then you will need the blinker fluid periodically.
09-25-2018, 07:28 PM
Changed my tail light bulbs and blinkers worked again. The next day they weren't. Was the front amber bulb this time. Check the bulbs again.
09-25-2018, 08:25 PM
Cruise-In II Veteran
If all bulbs are lit on steady with each the same brightness I'd replace the relay.
09-25-2018, 08:28 PM
Mr. Peabody
Ahh! How could I overlook such an obvious detail
Reminds me of when I once had a muffler bearing seize in the middle of a huge burnout.. blew everyones ear drums out.
09-26-2018, 11:43 AM
c4cruiser
It's weird when I tried to Signal left or right the indicator stays green and the signal light I'm signaling stays on
09-26-2018, 11:47 AM
RArline
got some new front signal lights going to change them n see if that works the wire inside seem to be attached and not blewn
Reason: Miss spelled word
09-27-2018, 10:38 AM
***** getting weird......while not signaling......the green indicator arrow stays on
