LT4 blower for LT1 Stingray
09-26-2018, 03:21 AM
09-26-2018, 06:53 AM
Quote:
Originally Posted by
Seannyc
This is what I have for the swap I no I need adapter plates map sensors and wireing harness am I missing something else ? If anyone can tell me what else I need and we’re to do the install
You’re missing the air baffle, balancer, and LT4 valley cover at a minimum.
09-26-2018, 11:30 AM
Is your corvette a dry sump ?
09-26-2018, 05:47 PM
U need a 17. Blower or gonna have problems with heat
09-26-2018, 09:18 PM
TorchZ51
i have it just didn’t post it
09-26-2018, 09:20 PM
sammy burks
no I’m a wet sump I found the right pulleys and Balancers
09-26-2018, 09:22 PM
onebad1lE
can u provide me wit the parts I need if u can part numbers for which sensor and map sensor and wireing harness
09-26-2018, 09:29 PM
I have several balancer for sale if u need one
09-27-2018, 03:52 AM
onebad1lE
im a wet sump so I need a ati Balancer
If u can tell me the part number for the Edelbrock pump and part numbers for the wireing harness and sensors
09-27-2018, 09:58 AM
Seannyc
Wiring harness and sensor kit
https://west-michigan-automotive-tec...ion-wiring-kit
09-27-2018, 03:47 PM
With stock boost you should be fine, do you have the intercooler pump?
09-28-2018, 01:55 AM
Seannyc
so this kit includes the sensor I wouldn’t need any other sensors ?
09-28-2018, 01:56 AM
Bruce_K
yes but I might add the Edelbrock pump they said it flows better idk how sure
09-28-2018, 06:50 AM
Seannyc
Yes it’s a better pump. That kit uses the GM Varimax pump
09-28-2018, 06:51 AM
Seannyc
that is correct
09-28-2018, 04:23 PM
TorchZ51
thx
10-01-2018, 02:37 PM
If you are wet sump, the stock z06 balancer wont work? What is the part number for the proper ati balancer?
10-02-2018, 04:20 AM
ArcticWhite
