CPR LT4 package goes 9.7 on stock blower
Supporting Vendor
Our customer in CA just ran his C7Z that has our heads/cam/ported blower/cooling/ and bolt on package and the 9.7 is what he put down! This is on a stock trans, converter, axles tire with a 15'' non beadlock setup. DA was also 19xx and this package is so easy to drive every day with zero quirks at all.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
More to come, stay tuned
This run was done on a non-prepped slick track. Tires spun quite a distance. Also it was a non-iced run so there’s more to be had. Stay tuned to CPR’s posts reguarding this build. Also full sizes OEM fronts, no skinnies.
Cordes Performance Racing (10-02-2018)
Very nice. Congrats!
She Does It Again
Took Ice to the track again yesterday and ran another personal best. Can anyone show evidence of a faster OEM blower (1.7) non-Nitrous C7 Z06 with a faster time?
80 degrees, DA approximately 1400
Excellent pass !. Great combo, i definitively want to to do heads and cam. I truly believe that combo is good for very low 9's in some negative DA. Looks like the track was having issues with the 1/8 mile trap measurement on your pass.
Nice! Who did the work on the blower?
Your 60' times are crazy, 1.3 -1.4. I have pretty much the same set-up, heads, cam, ported blower, 103mm tb, headers/x-pipe, 15% pulley, tune, etc.
My best is a 10.2 at 139 with a 1.62 60'. I've left off idle as well on the brake to 1700 rpm, nothing changes. . . 1.6 60'. Running 18" x 5" skinnies upfront and 18" x 12" out back with MT Dr's R, not spinning.
What's your secret or what am I doing wrong.
Great job!!
Great job!!
Great job!!
Great job!!
You're having torque management step in and you are not getting 100% power from the hit. My tuner finally figured mine out and now she's an animal out of the hole! Traction is now the issue. My 60's went from a respectable 1.56-1.58 down to a 1.46 and I think there is still more there? I didn't have much time to play with it that day. I wasn't getting full power until around 32 mph. He actually asked me if I was flooring the car from the hit when he was data logging because he couldn't believe the graph.
Great job!!
Great job!!
But I do see only 19 mph on the back half.
[QUOTE=3 Z06ZR1;1598212364]Lot of them on highway rolls. Nice run but it is all 60ft holeshot just what a fast 1/4 mile requires nice work!
But I do see only 19 mph on the back half.[/QUO
I think you mean quick and not fast as one has nothing to do with other,,,The eighth MPH was obviously not working.
[QUOTE=UBNZO6D;1598212506]
Who knows if the 1/4 mph is really correct either!
MPH is very consistent with ET.
