VIS TS Carbon vented hood - twin turbo build
hey guys, doing a TT build and leaning towards this style hood. Does anyone know if that hood offers enough clearance for my intake? It looks like it would work but don't want to make a big mistake, lol. My only concern is the front of the intake which is approx 2" taller than the factory hood. Thanks guys!
Wow, that’s going to be one friggin awesome rig when you’re done!
I would just do one of these VFN Sunoco hoods:
http://www.vfnfiberglass.com/0513vette.htm
Thanks CI GS! Yes, the Sunoco was my plan B. I really dig the sharp lines of the TS hood.... i'm about to pull the trigger on it unless i hear different from this thread. i hope it works, fingers crossed, lol.
Thanks crawler! It's pretty aggressive but will still have the creature comforts. My build thread is on the bullet.....lots of details and pics. Thanks
Received 1,194 Likes
St. Jude Donor '15
Link?
St. Jude Donor '15
Insane.
What do you use fuel pump wise on something like this? Has to be an insane amount of fuel
schpenxel, i'm going to use a large cam driven pump with 16 injectors. I'll run E on the street and methanol when i blast it. Turbo's are good for about 3k hp but will be turned way down while on the street. I'll have a another set of rear wheels/tires (15") when i want to play around because the 20's won't hold much power. I also built a little 5.3 LS turbo engine if this BBC proves to be too aggressive while on the street. My build should be wrapped up in the next six months or so. Thanks
St. Jude Donor '15
Very cool. I'll check out the thread on yellowbullet as well. There are some absolutely insane cars/builds/knowledge on that forum.
Amazing build as always, but to answer the original question, I don't think it will fit under that hood.
Thanks unreal and schpenxel! If the TS won't fit, is there another similar style hood that may work? I know the VFN will fit (i used the sunoco on a C5 build) but i will exhaust my search first. Thanks guys! Tracy
The hood I'm looking at, and may fit is the https://www.sigaladesigns.com/produc...charger-hood-1
99% sure I'm getting that hood, once I get around to ordering it.
CI GS (10-09-2018)
I’ve just finished combing through your YB build thread. That is one awesome piece of machinery you’re building man. Hell, if it was mine, I wouldn’t even worry about putting a hood on it! No matter what you do, that thing is going to look good from any angle.
CI GS, thanks for the props! We are both the same color..... the carbon fiber contrast would look great on silver.
The fiberglass one is nice too, and cheaper if you are just going to paint it.
I wasn't sure if the Mods allow a link.... but here goes. Thanks
https://www.yellowbullet.com/forum/s....php?t=2431794
