Problem getting auto out of Park
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I'm having trouble getting my 09 C6 out of park,especialy on an incline,I have a kwikLift and park on it in the garage. What could be the problem??l
Hi - I had a similar issue, but happened on a flat surface. Check out the links below. Not sure if you have the same issue, but this fix worked for me. Rather than tie back the part at issue, I simply clipped it off. The issue is apparently a low current issue for the electronic part that sends a message to the gear shifter to "unlock". I would encourage you to do more searches on this issue, there are quite a few of them. If you decide to tackle it, be careful for the orange indicator tab in the gear shifter, it can be easily broken, but not if you are careful. Again, search more, there are many videos out there as well. Good luck!
Jon
https://www.corvetteforum.com/forums...k-in-park.html
file:///C:/Users/Jon/Downloads/Auto%20Shifter%20Stuck%20in%20Park%20or% 20Unable%20to%20Get%20back%20to%20Park%2 0(1).pdf
Jon
Jon
Jon
Remove your console cover, cut off or tie back the plastic pawl and reinstall your console cover. 30 minutes and a free, permanent fix.
Cruise-In I Veteran
Right now I can't take the console cover off,I have been doing Chemo and both my hands are numb!! I have not been driving the vette much the last two years,the last time I drove it in August it was fine. When I get it fixed I plan to sell it,its only got 11,500 miles on it and just sits in the garage covered up!!
Hi HEB - I’m terribly sorry about your situation. If you live by me, I’d be happy to come over and take a look. Wishing you a strong and healthy recovery!
all my best,
Jon
all my best,
Jon
2020 C6 of the Year Finalist - Modified
Out of Park
Push bottom of start button to put car in accessory mode and shift to neutral. Start in N and shift to drive or back to P when done. This is in the Manual for your car. GL.
Cruise-In I Veteran
Thanks 2008 for the advice, I will try it!! jbripps I live west of Dayton,Ohio I'm sure your not close but thanks for the kind words
Another thing to try...after the car is started take your foot off the brake, put a bit forward force on the shifter, hold it there then put your foot on the brake and see if it will unlock and come out of park.
