Please help with this noise
Old 10-10-2018, 11:14 PM
titanescape
titanescape's Avatar
Default Please help with this noise
I have a 2007 Corvette with 45k miles. There is a squeaking noise under the hood. It's been hit and miss but I've heard it for a couple of days now so I really need to identify it. I do have some technical skills( do my own maintenance and auto repair) so hopefully it's something I can fix.
I've attached a youtube link so you can hear.
https://www.youtube.com/watch?v=HfqA...ature=youtu.be
Thanks for your help!
Old 10-11-2018, 09:13 AM
farmington
farmington's Avatar
Received 1,119 Likes on 798 Posts
Check your balancer.
Old 10-11-2018, 09:20 AM
titanescape
I was thinking that but I don't see any wobble at all. I wanted to make sure before I go down that road.
Thanks for the input.
Old 10-11-2018, 09:29 AM
farmington
farmington's Avatar
Maybe a belt tensioner
Old 10-11-2018, 09:44 AM
titanescape
If it is the tensioner, should I be able to remove the belt and create the noise turning it by hand? I know I can't turn the balancer by hand and recreate it.
Old 10-11-2018, 11:09 AM
farmington
farmington's Avatar
While it’s running spray some wd40 on the center bearing area. See if it changes.
Old 10-11-2018, 11:16 AM
titanescape
Easy enough. I will do that this evening and report back tonight.
Old 10-11-2018, 06:11 PM
titanescape
Got home and did a better inspection with a brighter light. The squeaking had stopped when I pulled in the garage but it has been squeaking all day. I thought I didn't have the harmonic wobble but it appears I was wrong. See attached video, I'm pretty sure it's the harmonic.
Old 10-12-2018, 12:29 AM
Cherokee Nation
Cherokee Nation's Avatar
Your balancer looks fine.
Old 10-12-2018, 09:21 AM
titanescape
Did you happen to see the first video? What do you think that noise is?
Old 10-12-2018, 10:56 PM
Pir8Diver
Pir8Diver's Avatar
Did the noise start after you washed the engine by chance? We've only had our 2007 vert for a week, but after washing the engine bay real good I noticed a squeak from the engine that seemed to increase with acceleration.
Old 10-12-2018, 11:52 PM
Cherokee Nation
Alternator bearing.?
Old 10-13-2018, 11:46 AM
titanescape
I have not washed the engine bay. It's been raining here a lot but no deep water driving either.
I thought about the bearing but the chirp seems further down..
I'm thinking it might be belt related and I'm just reading too much into it.
Old 10-13-2018, 12:35 PM
Dave S
Retired & lovin' it!
Support Corvetteforum!
Dave S's Avatar
You & everyone else are just guessing. Get yourself a mechanics stethoscope (they're cheap at any auto parts store) or a 2-ft section of garden hose & listen carefully at each rotating component. You will quickly know where the noise is coming from.
Old 10-13-2018, 11:00 PM
Dano523
Dano523's Avatar
Received 3,005 Likes on 2,168 Posts
Better video would help, but banking either a dry bearing in one of the two tensioner pulley's, the idler pulley, or the the A/C compressor clutch bearing going south instead.
Turn the A/C so the compressor clutch engages (instead of free wheeling instead), and if the noise goes away, it's the A/C compressor clutch will need to be replaced.
Old 10-13-2018, 11:10 PM
Jaime-Corvette
Jaime-Corvette's Avatar
that's funny because my car never did this noise... but I just changed my radiator and some coolant leaked out onto the belts and pulleys because a hose wasn't fully clamped (the one from the upper water pump to top of radiator on thr drivers side). Well while after driving the car I noticed my car was doing the same exact noise especially when I use gas. Idk if it's because I got the belts and pulleys a little wet or not, but in a few days or tomorrow if the noise stops I'll let you all know
Old 10-13-2018, 11:11 PM
Jaime-Corvette
That's a perfect idea
To Please help with this noise
Old 10-13-2018, 11:36 PM
Cherokee Nation
Now that you said belt,I had a noise but most of the time it was only on start up and shut down on my 08...Long story short i removed the Mitsubishi belt and put on a Gatorback belt and that was about 5 years ago and NO noises since......That was my first choice of the process of eliminations..
Old 10-15-2018, 08:59 AM
titanescape
Just an update to the noise. First off, I will get a mechanics stethoscope so I can do some detailed listening.
An old shade tree mechanic told me to get a bar of soap and rub it on the underside of the belt.I did that Friday night and the noise stopped immediately. I didn't drive much over the weekend so today will be the real test. I don't know if its's belt related or if that was just a quick way to silence the noise.
I will post a follow up to let ya'll know if the noise comes back or what's going on. Thanks for all the input and help on this.
Old 10-15-2018, 01:31 PM
Jaime-Corvette
If the bar of soap stopped the belt from making that noise immediately that could be because the belt is bad. I would start by buying a new belt. If it starts making the noise again, get a tube of hose and listen where the noise is coming from... it could be a pulley or bearing. If the noise comes from the crankshaft pulley (harmonic balancer) then that would be a heck of a replacement
Quick Reply: Please help with this noise
