Lash cap install / kent moore oil pump tool
LASH CAP INSTALL/ Kent Moore Oil Pump alignment tool
I have the stage 2 cam with the fuel lobe from BTR for my C7 LT1 and they sent me the LS7 lash cap. They said it should go on easy over the the stock fuel pump cap. Mine is not going on easy. Any suggestions or tricks to install this? Does anyone have the Kent Moore tool they want to sell or rent out for the oil pump alignment tool? Thanks,
I would get it hot to expand it.
Received 1,762 Likes
Patience is something I can work with I will just walk away & come back to it much later if something starts to get to me.. Plus I am like you the car can set for any amount of time dont have to have it to drive as a daily... Robert
Billy@MTI (10-15-2018)
I should be pulling the stock cam tonight and installing the BTR cam.
I am also struggling with removing the oil pan. Cant seam to get the cradle to drop down. Any suggestions? Thanks for all the help.
I agree with you Billy seems like about 99 out of a 100 of the c7 holds that # on pressure, Mine is even a little more at first until it gets really warmed up. But also here you can use a heavier oil & the pressure should be a little more for you..
I'm Batman..
Pro Mechanic
Ant
