Longevity of Cup 2 in HPDE?
I am curious to see how many track days are folks getting from the Cup 2 tires? I made the mistake of replacing the initial MPSS with Conti Extreme and the fronts are down to 2/32 (front) after 5 HPDE days and 3000 miles of driving. Running in the intermediate run group at this point.
Moderator
When I asked track rats what they do for such events scrubs were suggested. Pretty cheap and lots of life left.
I got 3 track days before the fronts became a slick with no tread left. That was 4 20 minute sessions for each day so didn't take me much time at all.
Received 8,915 Likes
The lowest cost way to go is with scrubs (once you pay for the wheels required).
Bill
In hot Texas weather (COTA, MSRH) they will usually last 7-8 track days with four 20-min sessions per day. You don't need tread for track days, but cording and delaminating is a different story.
To save money in the long run I went with custom spec 18" forgestars currently on r888r's.
cup 2 zp will last 6-7 hpde if you keep PTM on, and obviously sport 1 will allow you to keep the cup 2's running the longest. race mode or turning off T/C then probably only 2-3 track days if that.
Remember michellin themselves will warranty tires too.
I've also found that if you heat cycle the tires a few times on the street it will help with tire life and delamination. I try to heat cycle the tires 3 or 4 times on the street before I use them on the track. I've had much better luck since I started doing this. I can't remember who it was that suggested that to me but it has worked well. That and a track alignment.
Bill
Maybe I should have put I ran them for 30 miles or so and let them cool back down several times. I didn't push the car hard at all just normal driving. It's an hour drive for me to Raleigh so I just made 3 or 4 trips with the cups. That said they haven't delaminated since I started doing that.
Sorry about that. I wasn't trying to mislead anyone. It was suggested to me that I try this to help keep the tires from delaminating and it has worked. I had a problem with one strip of the tire peeling off with new tires but doing this with the last 2 sets it hasn't happened again. Not sure if this helped or I've just been lucky.
An instructor at Spring Mountain told me they run about 2 seconds slower on the Super Sports when compared to the Cup 2's
Tire life on track will depend entirely on how you drive. I usually get about 3 days out of a set. As others have said, true heat cycling really helps their longevity. By that, I mean run a session with them and then swap them out until at least the next day or ideally the next event.
I only got about 2 track days (10 sessions) out of my Cup 2's before the fronts delaminated. The rears were still in pretty good shape.
