Need to coooooooool down
So I am getting sick of overheating (going into limp mode where car puts the dreaded "engine overheating" message on the DIC) during my HPDE events with my 2016 Z06 A8. I end up overheating at about 16 minute mark of a 20 minute so I dont have a huge problem and I dont have gobs of money to throw at this so I am hoping some of you guys got actual experience with a few of the low cost options. So here is some of the things I was thinking about and see if anyone tried and saw any gains.
1. Remove all coolant from radiator and go with water and water wetter. I live in AZ so no freezing could ever occur.
2. Remove all coolant from the supercharger cooling system and go with water and water wetter.
3. Add one of the after market expansion tanks for the supercharger cooling system
Received 8,927 Likes
What year car and is it a M7 or an A8? What ambient temperatures are running in and what is the track length and what gears do you use?
M7s with the secondary radiator can run very fast laps throughout a normal HPDE session without over heating in temps up to 95 degrees. I know I have been able to do it for three seasons without coming close to over heating.
What do you consider over heating? I typically see mid 220s coolant and mid 270s oil temps on those hot days and those temps are far below the over heating range.
Bill
Bill
ktoonsez (10-13-2018)
So I am getting sick of overheating during my HPDE events. I end up overheating at about 16 minute mark of a 20 minute so I dont have a huge problem and I dont have gobs of money to throw at this so I am hoping some of you guys got actual experience with a few of the low cost options. So here is some of the things I was thinking about and see if anyone tried and saw any gains.
Bill
Bill
EDIT:
Using Cosworth app, oil got up to 320 and coolant was at 264.
For the race track, if you want to drive fast,
You need a perfect cooling.
Katech, for example, can help very well.
If you do not want to spend money:
-Disassemble the complete air conditioning system
Drive your machine always in manual mode and switch at the latest at 5700RPM
Cölestin
Cölestin
Cölestin
Cölestin
Unfortunately, the automatic model is perfect for the racetrack only with great modifications.
We have already made many Automatk vehicles for the racetrack.
Better you invest right once and then you really enjoy and have fun.
or, Change your Corvette with a Model 17 M7 handset
Cölestin
Cölestin
No, and No. Can't answer 3rd question. Do not know about the particulars. Having a 50/50 mix of coolant and distilled water are your best options. The coolant in the water raises the vapor pressure of the working fluid and also increases the boiling point of the working fluid as compared with just plain water. This is a good thing as boiling fluid reduces the amount of heat transfer the radiator can transfer from the engine. I am not a big believer in water wetter. It has a minimal effect on enhancing heat transfer from the radiator. The solution you seek is somehow you need to add a larger radiator to your ride. More fins are the solution to increasing the cooling.
The Chev (10-15-2018)
Actually, that's not true. Water and water wetter will move heat away from the engine far better than a 50/50 mix of antifreeze and water. The boiling point increase is almost 100% due to the systems being pressurized and not any function of the antifreeze. Yes, it's antifreeze, not coolant and antifreeze has less of a heat carrying capacity than water. Why do you think GM changed the mix to 60/40 for the intercooler? Because more water cools better. Water wetter works, but only on water, it has no effect on antifreeze. Water wetter and the other similar products act as water softeners and reduce the water's surface tension. This allows the water to reach areas in the rough cast cooling jackets that it couldn't before. This reduces hot spots around the combustion chambers and generally cools better.
Supporting Vendor
We are local to you sir and I have quite a few c7z's that do full road racing not HPDE stuff and they have zero overheating issues with our setup's. If you want to discuss your options shoot me a pm, email me, or come down to the shop.
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
ktoonsez (10-14-2018)
Received 2,051 Likes
St. Jude Donor '13
Did the DIC tell you to change the oil after that high temp?
Using 15W-50 oil or something different?
Did you get any coolant boil?
No I did not get a change oil warning. I did not see any boil but it is possible I am sure with the temps I get to. Since it overheats early I drive a lap and half in 5th gear to cool down and then get 1 more lap or 2 in. I get this every event except for the ones where we stay under 60 degrees for the day. Using the same oil as always.
Supporting Vendor
We have a few options that you can pick from, including a dual oil cooler setup that does not alter the bumper, and retains the brake ducts. In addition to that, we are finally happy and ready to release our blower reservoir that we use in our big cooling packages for the last two years- only catch is that it retains the OE heat exchanger, but changes the flow and removes the air from the system. The engineering has been done for some time, and should hit the market in the next two weeks.
These two systems combined will lower coolant temp 30* and lower oil temp 65* and can be installed in a long afternoon with normal hand tools.
__________________
"Keeping You on Track!"
http://www.gspeed.com
877-512-5180
Instagram_Facebook_YouTube
GSpeed C7Z Cooling Development
2014 NASA Texas TT1 Champion
2015 NASA Texas ST1 Champion
2018 NASA TTU & TT3 National Champions
2019 NASA ST2 National Champion
2019 NASA Texas TT2 Champion
2020 SCCA Majors COTA GT2 pole sitter
2020 SCCA Trans Am Road Atlanta SGT Winner
2022 NASA National Champion ST2
2023 NASA National Champion ST2
2023 NASA National Champion TT2
877-512-5180
Pure nonsense bud. 100% !!! I am laughing so hard that my side is hurting. You do not know what you are talking about other than maybe what you read in some BS market literature. I know what watter wetter is and capable of. Think of it as snake oil. It is a mere band-aid. The thermodynamic properties of a 50-50 blend of coolant-distilled water will yield the highest possible boiling temperture which is as good as you're going to get. Pressurizing the cooling system also raises the boiling point further. This solution will increase the vapor pressure of the fluid which increases the boiling temperature. You want to increasure the boiling temperature as you want the fluid in your coolng system to remain as a fluid and delay any onset to becoming a vapor. Why you ask? Liquids are much more capable of transferring heat away than pressurized vapor is. If you disagree then you know absolutely nothing about science. Sorry bud, but the Laws of Thermodynamics are on my side on this one. You're not a water wetter sales person perchance?
You seem stuck on the idea of vapor pressure. What you should think about is keeping the fluid "fluid", and not vapor. That is done by having a pressurized system, not by using antifreeze. Most importantly, water has a higher heat capacity (the ability to take heat away from the engine) than antifreeze.
I, my friend, have studied thermodynamics. Why don't you do the same before attempting to educate others on the subject.
The following 5 users liked this post by 6Speeder:
01REDSS (10-16-2018),
GSpeed (10-15-2018),
Mike Mercury (10-15-2018),
SL41 (06-15-2021),
You need to restudy thermodynamics my friend! Ethylene glycol (the major portion of antifreeze) has a heat index of 2.78, where water has a heat index of 1.0. The lower the number, the better the fluid transfers heat. Start by reading that carton of antifreeze (yes, that's what it is, NOT COOLANT.) You will see that as the percentage goes up the boiling point doesn't change much at all, but the freezing point does go down with increased percentages, that's why it is ANTIFREEZE. The major reason the boiling point is raised is due to having the fluid under pressure. The OP was on the right path with ditching the antifreeze, water with waterwetter or similar, will cool better than with antifreeze. Antifreeze is used for two reasons, to keep it from freezing (naturally) and as a lubricant for the water pump. The waterwetter provides the lubricant needed as well as helping the water move the heat out.
The car is a 2016 Z06 A8. The car goes into over heat mode and throttle wont go higher than 20% or so and the dash has the Engine Overheating warning (see image below for example). Oil is 320 but not sure on the coolant but it is sky-rocketed I am sure. This last track is only 1.2 and is highly technical and was in 3rd and forth all the time, ambient temp was 85, but have overheated at all the tracks in the phoenix area. Arizona Motorsports Park is 2.2 with lots of high speeds, using 3rd, 4th and 5th. So that should give you an idea of the wide range of tracks.
I think one of your issues is you are running the engine at higher rpms without a lot of speed due to the short tracks you are running on. I would try driving the tracks without using third gear and see if that delays the temp increase. Instead of gearing down to exit lower speed corners use the engine torque to pull out of them by opening the throttle sooner on corner exit while keeping overall revs down while moving at slower speeds. High rpms at low speed will pump a lot of extra heat into the cooling system. One of the reasons the M7 drivers don't see as many overheating problems is they choose to run in 3rd and 4th and maybe 5th. A similar gearing profile with the A8 would be 4th, 5th and maybe 6th if it isn't too tall.
The other issue is you don't have the extra engine cooling the M7 cars have with the Secondary Radiator. That radiator drops temps about 14 degrees. I don't think you can get 14 degrees reduction by reducing the coolant to water ratio. Even if you went to straight water with some Water Wetter and water pump lubricant I don't think you could gain that much drop.
Some of your problem may be driving technique. Can you improve your corner entry speed and speed coming off the apex of a turn? If you lose less speed in a turn that is less speed that has to be made up driving off the corner. Try driving without using 3rd gear and apply more throttle sooner in 4th to power off a corner. Sure 3rd gear raises the rpms and on the standard power diagrams that seems to indicate you would have more power to the rear wheels but at part throttle that diagram doesn't mean much. When the tires are limiting the power you can put down having the rpms high with less throttle opening to produce X HP isn't helpful if you can produce the same X HP by opening the throttle more at lower rpms in a higher gear. The other thing that happens is using the higher gear you can get smoother throttle application which helps you apply power sooner so you can be wide open sooner. The idea is to keep rpms down at the lower speeds without losing time on the track.
Bill
ktoonsez (10-15-2018)
