FS: NEW RAM ZF6 Hydraulic Clutch Release Bearing for Blue Tag 94-96 Transmissions
I'm going to ask a dumb question, but I couldn't find the answer on Ram's site: does this work with the stock pull-type clutch, or is it intended for use with a push-type conversion?
Matt, This is for the push type conversion. Ram doesn't make any pull type clutches for the C4's. I am looking at possibly using their push type conversion in my zf swap, instead of using the crappy chinese pull type stuff.
For this very reason, I installed a Ram clutch a couple of years ago using this piece and can recommend it though I only have a couple thousand miles on it.
Okay, that makes sense. Because if it were for a pull-type setup, my question was going to be how the hell it works!
