1985 heater not working
Old 10-15-2018, 07:30 AM
ellin5207
1st Gear
ellin5207's Avatar
Default 1985 heater not working
Took the vette out in 39 degree weather yesterday. Turned on the heater, cold air blowing out, windows became foggy. Heater was working in the past. Controls hard to slid.
Later, heater worked. Confused
Old 10-15-2018, 07:34 AM
Cruisinfanatic
Support Corvetteforum!
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
do you smell coolant?
Make sure coolant is full
Old 10-15-2018, 02:24 PM
Hot Rod Roy
Hot Rod Roy's Avatar
Does the valve on your hot water hose to your heater core change positions when you move the temp lever away from the OFF position? As you may know, that valve is in your engine compartment, at the front of your a/c evap. enclosure. There should be enough stored vacuum to actuate this valve with the temp lever several times, even after you shut off the engine.
Old 10-16-2018, 01:14 PM
856SPEED
856SPEED's Avatar
Heater core is going out if the windows fog and blowing cold air.
Old 10-17-2018, 01:04 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Best check under the passenger side floor mat for water
Old 10-18-2018, 01:25 AM
Hot Rod Roy
This is a confusing statement. "Heater core is going out" (as in leaking)? Or are you saying the heater core may be clogged?
A leaking heater core won't prevent the heater from working.
Old 10-18-2018, 12:04 PM
856SPEED
856SPEED's Avatar
Well,
whatever you believe, my heater core wasn’t heating the car when it leaked and fogged the windows. Was heating fine prior to that.
Old 10-18-2018, 05:27 PM
85WHITEZ51
85WHITEZ51's Avatar
Heater cores don't have a "going out" state which is where he may be confused. They either flow coolant (the valve) or they don't. If they flow then they either leak or they don't.
OP -
If it was hard to slide that sounds more like your flap that directs air from the evaporator core (AC) to the heater core. The rest of them are controlled by vacuum (air deflectors that direct air to the dash, feet, windshield, etc).
Things to check:
- Are you getting flow off coolant to the heater core? If not, the valve is bad as described above. It is vacuum controlled so would not be your "hard to slide" problem
- Is your heater core leaking? You would smell this and you would be able to feel moister in the passenger foot well if bad enough. An early on leak you would just smell. This is less likely though as if this was the case you would still get heat, at least until you ran low enough on coolant
- What is your coolant level? Make sure it's correct.
Me personally, I think it has to do with a sticking flap for the airflow since you said it started to work later.
Old 10-19-2018, 01:52 AM
JrRifleCoach
Well dang it Roy. you always find something wrong with our posts.
Maybe we should all just sit back and wait for your enlightenment?
To 1985 heater not working
Quick Reply: 1985 heater not working
