500 mile ride...Do you add air to your tires
We'll be heading for a long ride with 4-6 hrs of highway miles per day...does anyone add a few LBs to the tires??? We do it with our other cars and wondering if it's worth it on the vette?
Thanks in advance
Thanks in advance
Wouldn't that many hours of driving jack up the pressure on it's own? I'm almost thinking to lower it before your journey. And for what reason do you want higher pressure?
Received 19,293 Likes
'20-'21-'22-'23-'24
I see no sense in adding air if the tires are properly inflated to begin with. When driving, the tires will heat up and the air pressure inside will increase 3-4 lbs psi anyway.
Ulianokr (10-16-2018)
Simply driving will increase tire pressure anywhere between four and seven/eight psi. Therefore, increasing cold static tire pressure above the recommended pressure is ill advised and could result in dangerously overinflated tires.
Pro Mechanic
I usually kept my tires fairly close 2 the proper inflation anyway. If I was to add any extra air, I would have warnings throwing on the d i c all the time.
One time on a trip mine was so close that I had to stop the car and let two psi out of the tires to get it to stop flashing those annoying warnings all the time.
You should be running the proper tire pressure that your car calls for at all times. And it should be filled and check when the tires are cold before you drive any distance. Over-inflating your tires will cause a harsher ride, worse handling, and cause un-even tire wear.
Received 4,504 Likes
U.S. Air Force
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I never herd of adding air to tires cause you are going on trip, I take lot of trips, and what the manufacture recommends I set!
I have definitely heard of it and it is done to increase fuel economy. It can be pretty significant. Depending upon how difficult your tires are to turn at normal pressure, you might pick up 5 or 6 miles to the gallon. But I don't think you're going to do that on a C5 Tire because they already support the car so well with so much surface area. I'm sure it will gain mileage, but those gains will be offset by the D I C messages driving you insane. They will come up every 3 minutes for the entire time you are driving the car.
OP - adding extra air to your tires (especially the Corvette) will cause extra wear to the center of your tires and reduce tire performance. The cost of tire replacement will certainly offset any gain in MPG.
Are you filling the tires per the label on the door jamb or the tire side wall? If tire side wall, you're over inflating your tires. Side wall numbers are MAX pressure which would include while heated and Max load. A properly inflated tire will not trigger the DIC message when the tire heats up. I recently drove 1300 miles in 20 hours and my tires pressures never triggered the DIC.
If your running on run flats why would you want to have an even harsher ride? Myself I took those bricks off a long time ago and have NEVER regretted it.
The mileage increases you are claiming are not realistic. If your car got 20mpg and you get a 5mpg increase, that is a 25% increase in mileage. There is NO way going from proper inflation to grossly overinflated is going to make that big of a difference. Any any fuel savings are going to be offset by increased tire wear.
My mistake...I thought this was a Corvette forum where everyone had V8's.
