Finished my C1 electric power steering conversion
Pro Mechanic
Received 1,300 Likes
2023 C1 of the Year Finalist - Modified
Finished my electric power steering conversion on my ’60 today. The motor/gear unit was $100 on Ebay and the controller was $30 same place. The “extras” were outrageous; 8 gauge wire, 60 amp in-line fuse and the special 3/8” female spade terminals to plug into the controller were $35 more. I had some ‘double D’ tube left over from a previous PS conversion on a 1949 Drott road grader and used it to make the steering shaft adapters. The lower part of the steering column that came with the Toyota PS unit also fit the gear so all I needed to do was weld the “DD” sleeve onto it.
After extensive research online I decided to go with a late model Corolla gear because it didn’t require a third party controller to “activate” the PS controller. It just waits about 6 seconds, after ignition on, and when it doesn’t detect a VSS it goes into a ‘fail safe’ mode and powers up.
The C1 steering shaft is the required ¾” diameter and, after cutting the flats on the mill, fit the DD sleeve perfectly. The entire PS unit was a tight fit where it is hidden under the dash. It has to be just the right distance up the shaft and rotated to just the right angle so as not to interfere with the brake pedal, cowl air lever arm and windshield wiper drive cables. There are smaller motor/gear units but they are not recommended for anything above sub-compact weight cars. The controller is located behind the center console.
Works sweet and can’t wait to get the engine back in to try it on the road. Will also be ordering the ‘fast steering’ adapter.
Also learned many new things along the way; Pulling apart an old C1 column/box is a disgusting sloppy gooey greasy job. Spending the day under the dash (half the time repairing decades old previous “repairs”) is not that easy when one is 9 years older than the car. I answered a question I had put forth on the forum some time back about my February 27th, 1960 car having the stainless VIN plate on the door post. Seems that at one time the steering was rebuilt/replaced using a factory new box/column. There were virgin raised dimples where the VIN plate was supposed to be to position it for spot welding. Also, rather than unplug the individual turn signal wires at the wire junction, “Bubba” cut them and later twisted and taped them back together and slid them inside the column. I repaired and repositioned the wires outside the column because the new PS adapters have too much chance of snagging and cutting them.
Base parts
Double D and adapter
Lower column adapter
unit on column
Input shaft
Upper column half
Column joints
In place under dash
Done
Base parts
unit on column
Input shaft
Upper column half
Column joints
In place under dash
Done
The following 14 users liked this post by JF in MI:
58neverending (03-31-2021),
68hemi (08-28-2019),
69ttop502 (11-19-2018),
cardo0 (10-17-2018),
carl3989 (05-14-2022),
and 9 others liked this post.
Great work! Thanks much.
Very impressive ! Be sure to let us know how it handles after you get it back on the road.
I've always wondered what those looked like installed. Thanks for posting. Be sure to let us know how it works!
St. Jude Donor '07
your skills are awesome, you definitely think outside the box.... "I" would much rather have the assist on a R&P conversion than the antiquated C1 system; but CONGRATULATIONS
Bill
Bill
Very nice job. I put mine in the engine compartment, but it was a Saturn steering. It looks like the one you used is a little smaller. If I do it again, I think i would go the route you did.
Your going to like how it steers. (as long as the rest of the steering components are in good shape)
The following 2 users liked this post by hedgehead:
Cruzmeisters (11-19-2018),
Dreaming60’s (10-17-2018)
Received 3,048 Likes
C1 of Year Finalist (performance mods) 2019
I did not know about the Toyota parts working. I wonder how many other newer cars that use electric PS have parts that would work that my be even smaller?
I have the original steering type parts in my 57 but had the box rebuilt about 5K miles ago.
Pro Mechanic
68hemi
Here is a video that I found very helpful in making a decision on what parts to use;
Pay particular attention to the mount for the unit's powered end. I chose the one I found because the mount was removable (not cast in place) so that my own adapter could be easily attached.
68hemi (10-17-2018)
Thanks for the link to the video.
After extensive research online I decided to go with a late model Corollagear because it didn’t require a third party controller to “activate” the PS controller. It just waits about 6 seconds, after ignition on, and when it doesn’t detect a VSS it goes into a ‘fail safe’ mode and powers up.
Do you know what particular years are the same as what you used?
Pro Mechanic
68hemi (11-12-2018)
First for me. Really great work
Is the short shaft on the output side of the unit that you used to make the connection to the lower shaft also from the 09 Toyota? can you share the measurements you used when cutting the shaft and housing. Looks to fit well on your car and would save me a lot of time and guess work and maybe a few mistakes. Thanks
Billy
Billy
Pro Mechanic
Billy
Billy
The unit input housing outside diameter is a bit smaller than the inside diameter of the C1 column but you can make a bushing real easy using a piece of the discarded C1 column section. One caveat; when you cut the C1 column (usually needs to be done before disassembly to get measurements uniform) the inner shaft will sag, once cut through, and will pinch the saw blade in your metal band saw jamming and breaking the blade (don't ask me how I know this).
The following 2 users liked this post by JF in MI:
BILLY 63 swc (11-20-2018),
JF
It looks like the red wire for the 12 volts from ignition to the controller module goes to the bottom left pin in the 12 pin opening in your photo. Is that correct? Doing the wiring and do not want to burn something up. thanks
Billy
Billy
Pro Mechanic
BILLY 63 swc (12-01-2018)
