66 Tach Cable all of a sudden Too Short
cant believe this situation but reinstalled my TI distributor in the 427 and the tach cable (which was never removed) now comes up about 2 inches too short to connect to the tach drive. The distributor is oriented with the vacuum advance pointing forward to about the 12:30 o'clock position with the engine at #1 tdc and the rotor at the 1 o'clock position.
I looked under the cluster and the cable runs straight through the grommet with no bendds, therefore no slack. Someone else removed the distributor for repair so I'm not sure of the situation before it was removed. I do have one of those 90 degree adapters, but that won't help the cable length situation.
So, to replace the cable with a longer one, I'm going to have to remove the cluster to get at the connection at the tach. And I wonder about removing the grommet which also houses the speedo cable since that's the only way to get the cable head through the firewall.
Any my ideas what might be going on here?
Any my ideas what might be going on with the cable length or distributor orientation
Received 1,843 Likes
Replacing the cable with a longer one isn't the answer.
Tcheairs38655 (10-16-2018)
I agree....
If the tach cable is the correct one and the routing hasn't changed, the only remaining variable is the distributor orientation...
Just from memory the vacuum can pointing to 12:30 position sounds wrong. Seems like it should be pointing more to the 2:00 position or there-about, which would move the tach connection towards the cable end.
thanks guys. I'll try "clocking" the distributor clockwise a few notches. So, as long as the engine is at TDC and the rotor points to the #1 plug wire, I should be good for the startup? Maybe I can post a photo later this afternoon.
If firewall is 12 oclock shouldnt the vacuum can should be at 7-8 oclock position?
The following 2 users liked this post by phil2302:
DansYellow66 (10-16-2018),
Maybe you missed the part about somebody putting the distributor gear back on the shaft 180* out from where it belongs/used to be? If they did, you'll still be wrong no matter which way you drop the distributor in.
Or
Got it! Thanks guys
You've got 13 teeth on that distributor drive gear... an odd number.
Doing the math, each full tooth would be 27.69*. (360*/13)
The dimple on the gear should be installed under the rotor tip to be able to orient the distributor correctly.
If you orient the gear incorrectly, with the dimple on the opposite side of the rotor tip, you'll have a change of 1/2 of 27.69*, or 13.8*.
That amount can be significant if you have interference issues with the vacuum can..
Tcheairs38655 (10-17-2018)
