Those of you with a Camaro Serpentine & Sanden
NCM Grand Opening Veteran
St. Jude Donor '11, '17
How did you get it to fit with tall valve covers? Or did you have to use stock height?
St. Jude Donor '09
This is as high as it went with centerbolt covers. and I had to get the adaptor plated for compressor to fit serpentine system.
ratflinger (10-18-2018)
Thanks redcruz1120, I have the adapter kit & picked up some cheap-o stock height covers for testing. Appreciate the reply.
EDIT - Test valve covers came in and stock height works great, even clears my Comp Cams valve train, plus gives the connector on my alternator more room too.
Win-win
Win-win
Vintage Air has one for about $70 & Dirty Dingo has one for $50. I bought the Dirty Dingo one because I'm cheap.
https://www.dirtydingo.com/shop/prod...oducts_id=1622
http://www.tbiproducts.com/index.cfm...prod/prd20.htm
https://www.jegs.com/i/Vintage-Air/960/141805/10002/-1
