C6Z head milling?
C6Z head milling?
Looking for someone to shed some light and point me in the right direction in regards to milling the heads on my z06. I just picked up a stock as a rock '07 Z06 with 5900mi. Having a previous C6z my intentions were to get some good power with H/C + supporting bolt ons while the head issue gets rectified.
I've purchased a Vararam, TSP 1 7/8 headers w off road X pipe, MSD intake with a NW 102mm, BTR stage 4 cam + dual springs and trunnion upgrade, ATI super damper. I'm hoping that with ported heads from Katech, I'd be able to put down 600hp.
Not to go on a ramble here but I've been getting conflicting information regarding a BTR stage 4 cam and head milling. This also includes info right from the sales staff at BTR. I've been told not to mill the heads as fly cut pistons would come into play, I've heard from another person that you can mill .40. From what I gather here on the forum, people that have this cam have .30 milled heads with no issues.
What is your take on getting the heads milled with this cam? Would I be safe with a .30 mil to help me reach that 600hp mark? Any feedback is certainly appreciated!
STUCATZ (10-16-2018)
My HCI LS7 had heads milled .030. I run the Katech K501 cam (about .66" lift intake and exhaust) and 91 octane gas. With the crap gas the tuner had to retard timing so max advance is only 19*. Still 605 rwhp, 521 rwtq.
Right now I'm having a forged bottom end done. The heads were sent back to WCCH to be checked after 12K miles on their original rebuild and the valve guide clearances were .0011 or 12 in the top and middle and .0016 at the bottom. The original HCI build was done at 46K miles, with new OEM exhaust valves, Katech TiMo intake valves and CHE bronze guides.
Very nice set up. Seeing as how these ls7's are grenading at any time any place, I didnt want to chance it even with under 6000miles - so my thinking was that a huge cam would be cool while the heads are getting fixed LOL
Just seems the 94 doesnt take a lot of timing without the sensors picking up a bit of noise. Mine are shaved and can only run 16deg peak tq then slowwwwwly ramp to about 20 at redline.
STUCATZ (10-17-2018)
I was just worried with all the dif info I was getting even from BTR ... I think a 0.30" mill will be alright with those cam specs. I initially thought a cleanup pass was good enough but to squeeze some more power they'll have to cut em a bit
Maybe a compromise at a .020" mill. Yes its a pain, but you can always mill more off later if you want, but you can't put more back on if you went too far for your build.
