C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Mamo top end installed and tuned by cordes performance
Old 10-17-2018, 02:00 AM
Wyozo6
Wyozo6's Avatar
Default Mamo top end installed and tuned by cordes performance
Dropped the car(2011 zo6)off in phonex with Joe at Cordes Performance monday. He's installing and tuning mamo top end with exhaust and clutch. Put down 466 and 437torque initially so super excited to see end results. Confident Joe will take good care of me and get the tune spot on. Will post results.
Old 10-17-2018, 08:11 AM
FNBADAZ06
FNBADAZ06's Avatar
Looking forward to your results
Old 10-17-2018, 08:36 AM
jayyyw
jayyyw's Avatar
subb'd
Old 10-17-2018, 09:25 AM
TXGS507
TXGS507's Avatar
Received 1,679 Likes on 1,135 Posts
Its gonna be sweet...
Old 10-17-2018, 09:44 AM
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
Great choice, CPR is finishing up my forged bottom end to go with the top end work they did a couple years ago.
Good choice on putting in a new clutch. Are you having them install a remote clutch bleeder? Now is the time. Your stock "before" numbers are similar to mine on two other Dynojets in the Valley. Cam going in?
NicD does a good job of tuning and will work with you if further tuning is needed.
What color is your Z? I should be down there within a week to pick up my JSB 09 Z.
Old 10-17-2018, 10:14 AM
double06
double06's Avatar
When do you think you will get it back? Also is that a totally stock Z06 you are giving them?
Old 10-17-2018, 10:26 AM
Cordes Performance Racing
Supporting Vendor
Cordes Performance Racing's Avatar
Received 1,228 Likes on 775 Posts
Anytime we do a clutch a remote bleeder is put on. It's a white one (droooooollllll)
Old 10-17-2018, 10:28 AM
Supporting Vendor
Should be ready for dyno Fri. We are closing up early for street car takeover so if not ready for Fri it'll go on mon.
Old 10-17-2018, 11:48 AM
Wyozo6
Wyozo6's Avatar
Cam specs are 244 258 114+3
Old 10-17-2018, 11:50 AM
Wyozo6
Wyozo6's Avatar
Yes stock... Callaway intake and its been tuned.
Old 10-17-2018, 11:52 AM
jayyyw
jayyyw's Avatar
Not a bad cam. Almost identical to the RPM B3 and exactly what Pat G spec'd me when I asked for a little more mid-range torque.
Old 10-17-2018, 12:07 PM
double06
double06's Avatar
Default Good cam choice
Should do well here. Did you go with titanium intake or steel intake on heads. Good luck on dyno.
Old 10-17-2018, 01:24 PM
Pb82 Ronin
Pb82 Ronin's Avatar
Old 10-17-2018, 02:56 PM
Wyozo6
Wyozo6's Avatar
Don't recall whether they were steel or titanium. Had several conversations with Tony but can't say for sure. Doesn't s say on the spec sheet I got.
Old 10-17-2018, 03:26 PM
Donzo6
Donzo6's Avatar
What clutch did you go with? Any 1/4 miles in your future 😀
Old 10-17-2018, 03:32 PM
Wyozo6
Wyozo6's Avatar
Went with mamo RPS. Yes I'd like to get to a drag strip but Wyoming doesn't have one anymore so don't know when or where that will happen. Really like to get on a road course also.
Old 10-17-2018, 04:19 PM
AzDave47
AzDave47's Avatar
Smart move as always, Joe.
To Mamo top end installed and tuned by cordes performance
Old 10-17-2018, 04:36 PM
AzDave47
AzDave47's Avatar
That is a little stronger than my K501. You should see some good numbers on your build from CPR.
Old 10-23-2018, 12:05 PM
CASEWORER
CASEWORER's Avatar
Have you got any results yet?
Old 10-23-2018, 01:43 PM
Wyozo6
Wyozo6's Avatar
Car made 612hp and 520tq.
MTPZ06 (10-23-2018)
Quick Reply: [Z06] Mamo top end installed and tuned by cordes performance
