Wiring for door latches?
Premium Supporting Vendor
Location: www.EXOTICVETTE.com - FL Cruise-In VI, VII, & VIII
Cruise-In V Veteran
St. Jude's Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Anyone have the service manual with the plug part numbers and pinout for the latches?
I can probably get you something later tonight.
Both door actuators use the same connector, but they have different pinouts. Let me know if you need schematics. It's pretty involved, but I think most of the signals are just so the different control modules know what position the door latches are in.
Crazy Cowboy (10-22-2018)
Cruise-In V Veteran
You are the man! Thank you so much! I don’t think I will need the schematics because I’m going to use these latches on a custom built a car without the computer or modules. Mostly I just need the lock and unlock and trigger wires for the inside and outside buttons. Apparently GM does not sell the harness plugs without the harness so I am having a few people look to see if they can locate the plugs.
THANK YOU!!
THANK YOU!!
Cruise-In V Veteran
Only question I have is does your manual or the schematics tell you if everything is a positive 12v that is not listed as a ground?
Rock Auto has the connector housings for $4.74. I've seen them on Amazon too. GM part number 88952463.
https://www.rockauto.com/en/parts/ac...onnector,13045
You'll need to do some research to find out which wire terminals you'll need though. The service info I have just says the terminal part numbers are 'pending'. I'll look at some other places to see if I can get more info.
The schematics don't list voltages. It just says latch pin x goes to BCM pin y, for example. The diagnostic procedures might specify voltages though. The latch info is mixed in with the chapter for the whole keyless entry and locking system, so it's a lot of material to sift through.
Crazy Cowboy (10-28-2018)
Cruise-In V Veteran
I am installing C7 latches into an older Camaro. I was wondering if you were successful at connecting the lock/unlock and the door unlatch.
Looking at the pinouts, the pins are:
1) Door Double Lock Actuator Lock Control
2) Door Lock Actuator Unlock Control
3) Driver Door Unlatch Motor Unlatch Control
4) Driver Door Unlatch Motor Unlatch Low Reference
I assume pins 1 and 2 are simple lock and unlock 12V signals from the switch (or a keyless entry lock unlock signal).
For pins 3 and 4, is pin 3 a simple 12V control signal and pin 4 connected to ground?
I appreciate any input.
Thanks,
Jeff
Thanks,
Jeff
Cruise-In V Veteran
Thanks,
Jeff
Thanks,
Jeff
TMODcustoms (06-29-2023)
Hey Cowboy, this may be a long-shot based on the year of the post but is it possible you could email me the wiring schematic you came up with? I’m doing a custom install on an older project with a keyless entry/detection system as well. Looking for door lock/unlock, the outer touch pad for the door open/release! Thanks ahead of time and hoping to hear back!
Cruise-In V Veteran
if that doesn’t work I’m going to use another module that electronically latches with a signal and put a lock:unlock button on each door with an LED to let you know when power is on to the buttons. Good thing is you can use the manual release handles to get out too.
They work great for custom builds to have shaved handles or hidden button release without the loud clunk of a solenoid popping like they did old school.
on the past car I got it to work by the alarm system sending power to the Vette latch when it was off. I didn’t use the lock/unlock of the latch itself but basically when the alarm was armed it cut power to the corvette latch so the button wouldn’t work then when it was disarmed it had power. The only downside to that was the car wasn’t secure outside when you were driving (from say a carjacker). I am actually putting another set in an another car project right now and I picked up a dual pulse module DEI 452T is the module and the guy has another one on eBay. It outputs dual pulse which is what these apparently need to lock (or was it unlock). I will be working on it this week. If you want to DM me your number I’ll text you some info as I figure it out.
