FS: Mint Forgestar Drag pack
Forgestar F-14s, perfect condition. Almost brand new full drag pack. For a wide body corvette. Whole set up with less then 500 miles on them
Forgestar F-14 Satin black wheels (18x9 & 17x11)
Mickey Thompson 315/35R17 ET street R & Mickey Thompson sportsman s/r 26x10R18
$2000
Call/text Harley @ 256-5zero9-1818
$2000
$2000
$2000
How many passes at the track on them? Did you experience drag radial sway in the 1/4 mile runs? I just got a pair of Hoosiers for my rear. Did 2 passes on them and was scared to death. The sway was terrible. Found out on here that I need to ditch the front run flats and than I'll be fine.
Set up has made 2 passes at a 1/2 mile event, that's its.. and that's included in the 500 or less miles. car did 159.8mph on the set up.
I have had the car well in to the 100s just playing with it rolling into 2-3 gear on street and zero issues. with sway. I posted tire depth pics with the gauges as well. they are LIke new.
Yes car is lowered all the way on stock bolts, and rear bushings cut in 1/2.
I am selling as I don't track cars anymore normally, I drive them around on street tires and play that's about it. This set up was bought, used that one time, then I bought the car with both sets of tires. I don't need them.
They do not have sensors in them. The wheels work with sensors, but do not currently have a set in them just all black rubber valve stems. I tol these pics last week, and 2 had sensors..2 did not I had those removed and put on my street wheels to make a complete set. as the PO had 2 in the street tires and 2 in these. which made zero since to me.
They should as they fit C6Z with no issues, and both those cars swap out wheel and tires all the time. But I personally don't have a C7Z
