What
What
I am putting a 71 Vette coupe back together and have lost a part. The only place I can get a picrture, but no ID, is in my paragon catalog. In the catalog ,V40 issue, there is a section that is highlited in blue that says 1969-72 removable rear window and off to the right of that is a blue arrow. At the point of the arrow is a slender with 4 holes in it. That is the part I am missing. Please help me find a left and right. Thank you, Russell
Received 3,136 Likes
I must be looking at the wrong piece, the one I see in the cat should be riveted to the car. Was yours removed?
M
M
I also suggest you look in your catalog and buy a book called the Assembly Instruction Manual or AIM as it's refered to. Invaluable information on how our cars were assembled at the factory.
Sorry I can't help with the removable rear window. I have a convertible
The parts you are looking for are p/n 3972307 & 8. My AIM calls them Rear Upper Roof Moldings. I did a search and found a used pair that sold on fleabay in September for under $20 shipped. Perhaps a member has a set he/she would sell, so you may want to post in the WTB section. Apparently they are the same parts installed on '68 to '74.
Good luck.
Good luck.
Just for fun I looked up the parts in gmpartswiki.... take a look and check out NOTE 1.
http://gmpartswiki.com/getpage?pageid=41106
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I believe and someone correct me if I'm wrong, but the 1968-1969 moldings were made out of stainless steel and the 70-72 moldings were pot metal. If you don't find a set, I may have some here. Service@Willcoxcorvette.com
Willcox
Willcox
