No wobble ever, Buttttt !!!!
1/4 mile/AutoX
(1999 coupe with 84 K) When going to the Doc. the other day and after the 45 min. drive I heard my belts squealing bad, drove it home (wondering if I was going to make it ???) about 2 miles to go it stopped, thought that is strange, got home and my damper outside piece (pulley) is 3/4 moved to the rack side !!!!!!! The cam and heads was supposed to happen in a couple months, now it will have to happen sooner. My question is if I don't want to spend 300 plus for a ATI would this one be a good choice ??? https://www.summitracing.com/parts/s...model/corvette
Thoroughly chapped
Location: If you're not angry, you're not paying attention
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
If you need to save a couple of bucks, go with the Powerbond PB1117N, but use an ARP bolt.
The following 3 users liked this post by 'Shifter:
Bummer, Pounder. I hope she's up and running soon. A nice heads/cam combo was my next step before selling my Z06. Interested to see the results of your build.
Pounder (10-18-2018)
Pounder.....I put that exact damper on my 215k mile C5. It has performed perfectly with 0 movement. The only thing I will say is that it is an 8 rib balancer so the 2 forward grooves will not be used. No biggie.
Received 19,282 Likes
'20-'21-'22-'23-'24
Sounds like a good option for you. At least you were able to get it home OK.
Thats a nice HB, I was going to purchase that one but decided later to go with the PB1117N , I knew I wasn't going to track the car and a $73.00 Powerbond with the ARP bolt would be fine.
I am happy with it.
I am happy with it.
My z06 has the stock balancer still, but my LS swapped rx7 has an ATI with an ARP bolt. If I ever do a cam swap on my z06 I absolutely will go with another ATI.
You’re spending how much on a cam swap but going to balk at the extra $100 to get the best product and make your car the most reliable? Once you have the ATI in hand you’ll be happy you spent the extra change
1/4 mile/AutoX
my tuner says a 19 year old car will have major deterioration in the rubber of the damper, plus most new ones use a better compound ??? makes sense to me ???
1/4 mile/AutoX
well logic says if it lasted 19 years and 84 k must not be a horrible product ???? I WILL buy a better than stock one !!! just getting info and parts together for the cam/head job !!!! first project is swapping the trans in the 02 Z then rebuild that trans for the 99 !!!!!! it will be a totally different car when done !!!!
Well, whatever you decide to do, the difference between a good balancer and the best balancer is like 2 tanks of gas worth of money. Not really a whole lot if you ask me!
1/4 mile/AutoX
Received 3,042 Likes
The Summit Balancer looks pretty good. Make sure to use an ARP bolt with whichever one you choose.
Good luck with the build.
