Axle back install question
Hey guys, I just ordered the Hooker Blackheart muffler delete axle back system for my 2015 Z. I was reading over Borla's instructions on installation of their axle back and they have you removing the x pipe to install the axle back. Is this true? Do you need to remove the x pipe to install an axle back assembly? Doesn't seem like you would have to...
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,428 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
You do need to remove the centre x-pipe. Not enough room to extract the old exhaust and install the new. I've done 3 Z06's and the centre section had to be removed on all three. It's not that difficult and makes the job so much easier.
Take off the rear diffuser. Much easier. Did one last week
I left the x pipe on when I did mine, but I did remove the rear fascia. took longer to remove and install the fascia than the axle back
I have a 16z and I didn’t have to remove the xpipe. I did have to remove the rear lower fascia. If your doing it on the floor you just have to raise the rear high enough to remove the stock mufflers.
