WEAPON-X: ZR1 Carbon Fiber - Front Eye Brows and more!
St. Jude Donor '14
We're continuing our carbon fiber push with more of the odds and ends parts that weren't carbon from GM.
If you guys have any requests as well, just let me know!
In the works currently are:
- Larger ZTX Front Splitter ZTK - ETA Jan 2019
- Larger ZTX Rear Wing for ZTK with low, standard, and 50mm taller stands - ETA Jan 2019
. - Body Spoiler under ZTK wing in carbon with "fastback" look - ETA Jan 2019
- ZTX Side Splitter Caps for ZTK - ETA Jan 2019
. - ZTX Front Side Radiator Eye Brows - This is another one that gets me, like our rocker vents that aren't in carbon - ETA Jan 2019
- ZTX A Pillars - available now!
. - ZTX Side Rocker Blades - ETA Jan 2019
- ZTX Rocker Vents - available now: https://weaponxmotorsports.com/produ...12384373506097
. - ZTX Quarter Vents (above rear wheels) - ETA Jan 2019
. - ZTX Diffuser - more aggressively vaned than our existing model - ETA Feb 2019 (here is a sneak peak, but I want to make some changes still)
- Diffuser - available now: https://weaponxmotorsports.com/produ...rand-sport-z06
. - ZTX Tail Light Bezel Trim - available now:
. - ZTX Side Diffuser Vents - ETA Jan 2019
- ZTX Seat backs for lower seats - available now!
. - ZTX Wiper Cowl - ETA March 2019
. - ZTX Radiator Duct - ETA March 2019
. - ZTX Raised Vented Cowl - I am very excited about this one! - ETA Feb 2019
The following 3 users liked this post by Ben@WeaponX:
Definitely in for the larger front splitter. This car needs more front downforce to balance the rear wing in the high position. Does it wrap around and shaped to maintain the under wing? Any idea on cost?
Regarding the trim pieces, are these molded products or are then CF wrapped OEM parts?
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
Carbon Fiber.....yum!
St. Jude Donor '14
Here is our ZTX Wing in the works.
I knew you'd like these!
The following 2 users liked this post by Ben@WeaponX:
Palantirion (10-20-2018),
WzUpDoc (10-20-2018)
Received 1,767 Likes
Come on now Carl! I feel like you guys don't even know me sometimes?? JK man. Yes, we use the standard 2:2 and if you look at the rocker vents above, it will give you a good idea
Yes, I took a closer look at this because of your remarks actually. And yes, it will wrap around the sides similar to the OEM unit. As for pricing, I am not sure just yet. I know my cost per part, but I haven't had a chance to get into packaging, freight, etc. It will be very reasonable by comparison to the OEM parts though.
We only make autoclathed prepreg replacement parts, not adding weight to OEM parts or dealing with core swaps etc. Our smaller parts have billet milled molds, larger parts are cut on a 5 axis machine out of foam and then the mold is created.
Thanks Ben. Just to confirm it wraps around the bottom so the underwing can mount to it, correct? Also, are you doing any sort of CFD or other modeling since you are enlarging it? Since it's technically a front wing I imagine shape matter more than your traditional flat bill splitter.
Look under the stock wing, it has large square open areas for the attach fasteners. I’m sure this reduces the down force performance.
To follow up on Poor-sha's post, I wish someone would make canards for the front fascia. I agree there is way too much understeer in high speed corners.
St. Jude Donor '14
St. Jude Donor '14
I also thought about making more aggressive eye brows that stuck out 25-50mm more as well to channel more air inwards.
Ben,
As i undertstand it, the end caps help move air past the front wheel wells. Downforce is needed on the front. From the leading edge of the front fenders to the outboard grills, the front fascia contours in or forward. This area creates a nice spot for a canard. Take a look at the link below; i think this would work;
https://www.carid.com/apr-performanc...leid=649900432
Ben@WeaponX (10-20-2018)
St. Jude Donor '14
WEAPON-X: C7 ZR1 High Wing Mounts!
Had a few guys asking, so we knocked out a high wing mount approx 2" higher and have them 3D printed and are moving into production as soon as I mount them up. From our CFD, our new larger front ZTX splitter should balance the larger ZTX rear wing we're making as well for you track guys.
WzUpDoc (11-06-2018)
Ben@WeaponX (11-09-2018)
I am perhaps equally concerned about the edge roughness on what I presume to be the WeaponX part in that pic. May be good relative to other aftermarket manufacturers, but it LOOKS aftermarket next to the OEM piece.
