Help!
Old 10-19-2018, 05:50 PM
itsamenow
Navigator
itsamenow's Avatar
Default Help!
Got a quick question for all you C4 experts...
I was sitting in my car (1987 Corvette), had the engine running, air conditioner, and the radio. I used the cigarette lighter and when I pulled it out, I lost interior lights, radio and air conditioner. I replaced the main
pwr acc breaker thinking that would fix it. but it did not. What else is there that would knock out those particular things? I have not looked at the individual fuses yet because I didn't think the lighter would kill all
those things at the same time. Any help would be appreciated.
Old 10-19-2018, 10:25 PM
Cruisinfanatic
Support Corvetteforum!
Cruisinfanatic's Avatar
Location: Clifton Park, NY ..............Clearwater, FL ... 85 Original Owner
CTSY Fuse
Don't use the lighter
Old 10-20-2018, 10:39 AM
FOURSPEEDVETTE
FOURSPEEDVETTE's Avatar
Originally Posted by Cruisinfanatic
CTSY Fuse
I agree.
Old 10-20-2018, 03:10 PM
65Z01
65Z01's Avatar
Cruise-In II Veteran
Sounds like you may need to replace the lighter element.
itsamenow (10-20-2018)
Old 10-20-2018, 11:52 PM
itsamenow
Navigator
itsamenow's Avatar
Just wanted to say thanks for the info. Replaced the ctsy fuse and everything is back. Also replace all breakers (looked pretty grody). I guess what was throwing
me was the fact that I lost A.C. also. Specs call for a 15 amp. I pulled a 30 out of it. So, I put a 30 back in it. Was working fine until I used the lighter. (Guess I wont
be using the lighter any more :-) ).
Old 10-21-2018, 07:29 AM
Cruisinfanatic
you should be replacing with a 15
Old 10-21-2018, 07:37 AM
hcbph
hcbph's Avatar
You could try replacing the lighter and socket. Sounds like there's a short in it somewhere.
Old 10-22-2018, 10:15 PM
itsamenow
Navigator
itsamenow's Avatar
I don't have any idea how many people have worked on that car before I got it. I assumed that the 30amp was in there because of the A.C.. Would a 15amp be big enough?
Old 10-22-2018, 10:16 PM
itsamenow
Navigator
itsamenow's Avatar
You're probably right. It's as old as the rest of the car. (original equip.)
Old 10-23-2018, 07:51 AM
WhiteC1
WhiteC1's Avatar
If the fuse panel calls for a 15amp fuse, DON'T put a 30amp fuse in! The fuses are sized to protect the wiring in the circuit from overload. If you use a larger fuse, it could easily lead to a lighter gauge wire in the circuit melting before the fuse blows. Worse case scenario, you start a fire under your dash. The blown fuse is telling you something... Fix the problem. Oh, and by the way, quit smoking, it's not good for you!
Regards,
John
Old 10-23-2018, 08:41 AM
pacoW
pacoW's Avatar
you're asking for a cockpit fire by putting a 30amp fuse where a 15amp should go. Never over size fuses.
Old 10-23-2018, 01:48 PM
DGXR
DGXR's Avatar
For everyone suggesting "don't use the lighter," are you saying don't use the socket for anything? Or just don't use the cigarette lighter element, specifically?
I use the socket for cell phone charging which I understand is a relatively low draw compared to the lighter element, so I don't anticipate any issues with this kind of use.
Old 10-23-2018, 02:35 PM
Cruisinfanatic
In the OP's case he shouldn't because it's blowing fuses. What does that have to do with you?
Old 10-23-2018, 02:38 PM
DGXR
DGXR's Avatar
I'm also using my lighter socket. Not meaning to threadjack. Can you answer my question?
Old 10-23-2018, 03:03 PM
vette196
vette196's Avatar
Yes I'm curious as what the answer is, I use it for the cell phone and radar detector
"What does that have to do with you?"
maybe its the written word, but that sounded like a snarky response considering its a discussion forum
Old 10-23-2018, 03:04 PM
pacoW
pacoW's Avatar
I would not use the socket at all, pull the console plate and check the wiring for a short, if the wiring looks okay replace the socket, cheap insurance.
DGXR (10-24-2018)
Old 10-23-2018, 07:19 PM
Cruisinfanatic
No one said YOU couldn't use it if you are not blowing fuses caused by using lighter socket
To Help!
Old 10-23-2018, 07:24 PM
Cruisinfanatic
you answered someone that doesn't have a problem
Old 10-23-2018, 10:16 PM
Hot Rod Roy
Hot Rod Roy's Avatar
There are hundreds of thousands of Corvette C4 owners who don't have a problem with blowing fuses when they use their cigarette lighter socket. If you're not having a problem, you don't need to worry about it. If you ARE having a problem, then it's time to fix it, but it's a very rare problem! Does that answer your question?
Hint: Don't let any coins, metal objects, or liquids get into your socket!
DGXR (10-24-2018)
Old 10-24-2018, 06:04 AM
ghoastrider1
ghoastrider1's Avatar
btw, a penny fits perfect in that lighter socket..dont asl how I know.
Quick Reply: Help!
