FS: Ecs Paxton novi 2000 kit. New head unit $2600
Yes, removed this from my running car. I have all the brackets, intercooler, boosta pump kit, crank pinning kit and injectors. Only thing I don't have is a new belt. Has 3.4 pulley also. You are welcome to come inspect it.
Car made 642 on 9-10 lbs. the motor was stock with a mild cam. Fairly typical for most ls2 cars on similar levels. I have the dyno sheets. I also have a fast 92 intake and an electric water pump off one of my other cars. If interested call as I'm not in here often. Thanks.
Im thinking about buying the head unit if i could get it for $1000. Is it self lubricated or would I have to tap the oil pan? I have a ECS 1500 now do you know if the head unit bolts on to my stock 1500 bracket?When I get home tonight I'll do some research. Thanks
